07 springs
Old Dec 31, 2007 | 01:23 PM
Z33_kid's Avatar
Z33_kid
Default 07 springs
well iv heard that putting springs on a 07 is a good idea and a rare chance you will mess up the chamber or shocks?
Old Dec 31, 2007 | 01:32 PM
HR Autoparts's Avatar
HR Autoparts
HR Autoparts
depends on the springs, a more aggressive drop will create more negative camber and also blow the stock shocks faster.
Old Jan 1, 2008 | 10:30 AM
Gsedan35's Avatar
Gsedan35
07, 06, 05, 04 or 03 it's the same story and something to run a search on since it is a topic that is pretty much on every page in this section of the board.
Most springs offered for the Z do not have enough stiffness to cause issue with the oem shocks because they aren't much stiffer then oem. In a few cases it might be a better idea to upgrade the shocks to simply get better control. In a few of my past posts you can find mass spec lists for aftermarket 350Z springs to you can compare if you wish.
Old Jan 2, 2008 | 08:13 AM
stunnashadeson's Avatar
stunnashadeson
search is your friend.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
