Wheel bearing & hub - time to install these puppies
Where can I get the best price on a front hub assembly...I wheel is shaking as well and I took it to Firestone and they qume $386 for the part and at least $150 for labor...can I get it cheaper somewhere else, cause they told me as long as the part was new, they'd change it for me. Please help...I feel like the wheel's gonna fall off at somepoint and it's my daily driver...
Important to keep hub clean, shiny and in spec for runout otherwise it affects the rotor [thermal conductivity] and may induce [add to] warping.
The hub just like wheels is a part of the thermal sink for brakes.
Originally Posted by accordfreak
what accelerates the wheel bearings to go bad? spacers? heavier wheels? is this common on nissans?
My bearing went bad this weekend. Never noticed it before, but my caliper began to rub on the rotor pretty bad. Scary ****, and what sucks is that my extended warranty ended 2 months ago.
In any case, at 67k miles, i didnt expect something like this to go bad soo soon. Specially under moderate driving.
Originally Posted by leeboyNY
Is it necessary to change the hub along with the bearing or can you just replace the bearing only?
Machines are built around existing products---easy cross
How can you know if a bearing is bad w/o removing it? I hit a curb and knocked out the alignment a few weeks back. Got the car realigned and now I hear a noise coming from the pass side rear. Almost sounds like a tire rubbing, but it's very faint. Most people can't hear it, but I can.
CrowzRSA
Sep 21, 2015 04:00 PM
