Wheel bearing & hub - time to install these puppies
Old Jan 4, 2008 | 03:48 PM
moog's Avatar
moog
Default Wheel bearing & hub - time to install these puppies
Will probably be doing these this weekend. I will do a step by step DIY if all goes well.
Old Jan 4, 2008 | 03:53 PM
SuperBlack350z's Avatar
SuperBlack350z
are those teh fronts? how much does that kit run per side? Good luck with the install. I want to do this soon as well.
Old Jan 4, 2008 | 03:57 PM
moog's Avatar
moog
This is the rear. The front is a single hub assembly w/ bearing. The rear has separate bearing & hub. I got mine from Riverside Infiniti.
Old Jan 4, 2008 | 06:43 PM
Axelerate's Avatar
Axelerate
I just got the bearings for mine, but I took it to a shop to install them since I don't have a bearing press.
The fronts are very easy to do.
Old Jan 4, 2008 | 07:42 PM
moog's Avatar
moog
How much did the shop charge? I don't have a press either.
Old Jan 5, 2008 | 03:20 AM
Axelerate's Avatar
Axelerate
Three hours of labor @ $50 an hour.
Old Jan 5, 2008 | 07:41 AM
Kolia's Avatar
Kolia
Looking forward to the DIY!
Old Jan 5, 2008 | 10:12 AM
Equate's Avatar
Equate
I'm lost so did your stock wheel bearings fail? if not why the change?
Old Jan 5, 2008 | 10:25 AM
moog's Avatar
moog
yeah, the bearings are bad...bad vibration and wheel actually wobbles a bit
Old Jan 5, 2008 | 10:33 AM
Try&keepup's Avatar
Try&keepup
How many miles did you have when it failed?
Old Jan 5, 2008 | 12:30 PM
moog's Avatar
moog
don't know exact mileage, but they've gotten progressively worse recently. I have 91k miles.
Old Jan 10, 2008 | 05:14 AM
moog's Avatar
moog
Installed the passenger side last night, and it was a little more difficult than I thought. The bolts that hold the hub onto the axle aren't easily accessible. I had to pull the driveshaft out of the axle to get enough room. Vibration and noise has gone down A LOT. There is still a slightly pulsing noise from the drivers side bearing, which I will tackle this weekend.
Old Jan 10, 2008 | 05:31 AM
RKnight's Avatar
RKnight
Does the hub pictured on the left, have a section that slips into the center hole of the bearing on the right? If so is it a press fit?
Old Jan 10, 2008 | 05:59 AM
moog's Avatar
moog
The hub does need to be pressed into the bearing. It's not too bad, I took it to a local garage and they pressed it in for free cuz the boss wasn't around.
Old Jan 10, 2008 | 06:02 AM
SuperBlack350z
Good deal. I'm guessing you won't be doing the write up ?
Old Jan 10, 2008 | 07:05 AM
moog's Avatar
moog
I'll do a write up, but I didn't press the hub into the bearing. The rest of the installation I did.
Old Jan 11, 2008 | 11:19 AM
noodleman's Avatar
noodleman
i think this is the first time i've seen the hub without rust. I didn't know it was silver lol.
Old Jan 11, 2008 | 11:27 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
One of my bearings went bad at around 50k. I blame it on my new rims and drop. The bad bearing started making excessive squeaking noises. I think I paid 160 for labor on mine. Hopefully none of my other bearings go out anytime soon.
Old Jan 11, 2008 | 06:28 PM
moog's Avatar
moog
Finished the drivers side tonight which only took about 90 minutes. Everything is smooooooth now.
Old Feb 3, 2008 | 07:54 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
did you have to purchase the hub bolts, or did it come with the hub?
