SPC a-arm install, spindle nut doesn't work
Old Jan 8, 2008 | 02:13 PM
VIZAGE's Avatar
VIZAGE
Default SPC a-arm install, spindle nut doesn't work
Even though I fixed the problem by using back the factory nut. Just wondering if anyone else had a small issue with the spindle nut that came with the kit. Looks like a kings crown. Not sure of actual name.
But I went to install and tighten and the nut was to small. It just started to pull up into the steering pivot arm, where the conical bushing was. The nut is to small. What's up with the supplied nut of SPC's kit? I quickly undid and being the stock nut was the proper one, I just used it back. No issues. Anyone else have this issue or know something about it?
Old Feb 4, 2008 | 12:37 PM
joymykaduee's Avatar
joymykaduee
Default SPC nut....
I had the same problem. I had the kit installed about 10 months ago, never had any problems until yesterday. Drove over train track (30mph) or slower not sure...my A-arm popped out of the steering pivot arm. I was pissed cause my cousin said the guy who installed it didn't put a washer with the SPC nut they gave...i forgot if it came with one or if it even needs one...? So your saying the factory nut will fit with no problem? i should probably get an alignment after i install the factory nut huh?
Old Feb 4, 2008 | 12:50 PM
VIZAGE's Avatar
VIZAGE
That's right. No washer came with my kit. So I just but back in place the stock nut. Worked perfect. Yes, you will defiantly need a alignment.
Old Feb 4, 2008 | 01:22 PM
joymykaduee
cool thanks a lot man
Old Feb 4, 2008 | 09:08 PM
Eazzy's Avatar
Eazzy
So happens that IS called a Crown Nut and Id call SPC and have a little chat with them
Old Feb 14, 2008 | 09:14 AM
JCstart's Avatar
JCstart
I just bought this and I'm preparing fro the installation...
do you have pics of this nut ? more details of what I should do to install it correctly...
I know that I will have to buy the metal conical lower ball joint seat bushing...
thanks for your help !
Old Feb 14, 2008 | 04:33 PM
VIZAGE's Avatar
VIZAGE
I never had pics of this. And my car was totaled not to long ago, so no pics. Your kit might come with the right one, I don't know. But in my case it was safe to use the factory nut back onto the spindle.
You don't have to buy another conical bushing. Just rent or get a small gear puller to pull off. Very simple.
m_0g
Jun 3, 2021 10:05 AM
StateNuke08
Oct 31, 2015 05:01 AM
Tomek350Z
Suspension
Oct 11, 2015 08:32 AM
Shane86
Sep 17, 2015 05:33 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
