Realistic Shop Installation Quote...
Old Jan 9, 2008 | 10:05 AM
trodis's Avatar
trodis
Default Realistic Shop Installation Quote...
As the title reads, I am bringing in my Hotchkis TVS (Springs and Sways) to the local shop for install. I am wondering what the fellow members have paid in the past and what a realistic quote would be? Its an 07 and I was quoted
~500-600 good/bad?
Thanks in advance
Old Jan 9, 2008 | 10:07 AM
Lawy'dU's Avatar
Lawy'dU
Originally Posted by trodis
As the title reads, I am bring in my Hotchkis TVS (Springs and Sways) to the local shop for install. I am wondering what the fellow members have paid in the past and what a realistic quote would be? Its an 07 and I was quoted
~500-600 good/bad?
Thanks in advance
I would say bad, but I would also say do it yourself.
Old Jan 9, 2008 | 10:08 AM
trodis's Avatar
trodis
I dont have the tools to do it, so doing it myself rules that out
Old Jan 9, 2008 | 10:09 AM
iStan's Avatar
iStan
ZR
Find some peeps locally to help you out. Buy some brews and food, you'll be set.
Old Jan 9, 2008 | 11:11 AM
hulikner's Avatar
hulikner
Doing it yourself requires a wrench and a local auto zone for spring compressors...
Old Jan 9, 2008 | 12:19 PM
ev0k1ll3r's Avatar
ev0k1ll3r
its really not to bad at all i dont think i remember even needing a spring compressor for the back but the front it is necessary. besides that, just a floor jack some stands, a good socket set and open end wrenches should do the job. save the money for a good alignment afterwards.
Old Jan 9, 2008 | 02:59 PM
HR Autoparts's Avatar
HR Autoparts
HR Autoparts
500-600 will buy you more than enough tools to get the job done, and you will have tools for your next mod
Old Jan 9, 2008 | 03:05 PM
___DJK___'s Avatar
___DJK___
500-600 sounds reasonable if it includes the parts.
Old Jan 9, 2008 | 04:13 PM
Morris's Avatar
Morris
If you need to pay someone to do the job, I think 3 hours labor would be max that I would consider reasonable.
I am not sure about hourly rates in your area, but here it is $70 - $80/hr. So, in my case, I don't think anything over $320 is reasonable.
Old Jan 9, 2008 | 04:16 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
~500-600 good/bad?
Thanks in advance
Springs/Sways/Camber&toe = 500 sounds fair.
for me i paid springs/Camber installed = 250 + Pak of Marlboro. ( almost 1.5hr)
And i heard sways takes more time then install springs
Old Jan 9, 2008 | 04:25 PM
VIZAGE's Avatar
VIZAGE
Sways take more time than springs? Are you kidding me? Sways are easy as it gets. I'll install the both sways before anyone could install one spring. Probably the most simple mod on the Z.
Old Jan 9, 2008 | 04:28 PM
iStan's Avatar
iStan
ZR
^The only thing that gets annoying is if your exhaust gets in the way
Old Jan 9, 2008 | 04:37 PM
VIZAGE's Avatar
VIZAGE
I had to drop one side of my Greddy exhaust to install. No problem. Just took about an extra 5 min. Is that what your referring to, or rubbing issues?
Old Jan 9, 2008 | 04:43 PM
iStan's Avatar
iStan
ZR
I had to drop both sides of my Nismo and it took a while. Dealership=Air Tools, me=broken knuckles
Old Jan 9, 2008 | 04:45 PM
jcpeyton's Avatar
jcpeyton
I had Stillen sways, Tanabe Sustec Pro Type I coilovers and Prothane bushings everywhere possible, plus GT-Spec front and rear braces installed for under $250. That is about 3 hrs shop time @ $80/hr. Later, I switched to nismo end links and did it myself. My advice is do as much as possible yourself and save the $ for a truly professional alignment.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
