(help) changing front springs
Old Jan 18, 2008 | 12:57 PM
marques1's Avatar
marques1
Default (help) changing front springs
I have run into a problem i have the front spring and strut off. I'm trying to get the spring out but the bolt up top that loosens everything turns along with the thread to so it won't loosen it just turns and keeps turning along with the thread. What should i do? I tried wd 40 that did not work
Old Jan 18, 2008 | 12:58 PM
blktrack350's Avatar
blktrack350
impact gun. its that simple. make sure you have the springs compressed
Old Jan 18, 2008 | 01:52 PM
ttuberz's Avatar
ttuberz
+1. That's what I used to install my tein s-techs and worked fine.
Old Jan 18, 2008 | 02:21 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Let's spell that out: to properly and safely remove that nut, he needs a specific tool: a coil spring compressor. Once mounted and tesionsed on both sides of the spring, it'll remove the tension on the spring and allow marques1 to easily remove that nut. Reassemble in reverse order. Having access to a FSM would also help things immensely!
Old Jan 18, 2008 | 02:22 PM
350ZTheStandard's Avatar
350ZTheStandard
+1 also wouldn't hurt to have a friend helping out
Old Jan 18, 2008 | 03:36 PM
Russ@Z1's Avatar
Russ@Z1
Use a close end wrench to turn the nut while securing the rod of the strut with channel locks or adjustable wrench.
Old Jan 18, 2008 | 03:37 PM
marques1's Avatar
marques1
thanks guys i got a shop to do it. Now i have ran into another problem. I'm trying to put the strut back on the car and the holes dont seem to align right. is that because when putting the top back on the strut he moved it to far to the right or left? I thought the top would only go on one way.
Old Jan 18, 2008 | 03:47 PM
mavtais's Avatar
mavtais
You have to make sure the hat goes on in the right orientation. Loosen the bolt and turn the hat, then retighten.
Old Jan 18, 2008 | 04:43 PM
VIZAGE's Avatar
VIZAGE
^+1. You right the top will only go on one way. You just have to align it up. Don't worry, next time will be a lot faster. By the way, what type of springs did you go with?
07ZEKE
Aug 23, 2021 09:15 PM
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
