Power Understeer
Old Jan 21, 2008 | 06:56 PM
mgtibbetts's Avatar
mgtibbetts
Default Power Understeer
What would cause power understeer in a RWD car. For instance, the car turns in well under braking and in short turns but in long sweeping turns it understeers when even the slightest amount of throttle is applied.
Old Jan 21, 2008 | 09:30 PM
terrasmak's Avatar
Swaybar setting , to light of a rear spring, what your tire stagger ?
Old Jan 21, 2008 | 09:43 PM
infiniteracing's Avatar
infiniteracing
You have to be on balanced throttle before the entry of the corner on long sweeping corners. Otherwise the weight transitions from the front to the rear, taking the load of the front tires, which can (will) cause understeer. RWD cars always created understeer just before power oversteer.
Old Jan 22, 2008 | 01:00 AM
WA2GOOD's Avatar
WA2GOOD
^^ Well said. It would help to know what the entire set-up includeing tire stagger (F to R) difference is, to actuall offer any type help, though.
Old Jan 22, 2008 | 05:27 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if the car is stock, this is exactly how it's designed
without listing all the specs, from tires to alignment to pressure, etc etc, there really is no way to give you a 'why'
Old Jan 22, 2008 | 07:33 AM
mgtibbetts's Avatar
mgtibbetts
Setup is as follows: Front tires 245/40-18, Rear tires 275/40-18, stillen front and rear sways, cusco zero 2 coilovers, cusco a-arms. 2 deg camber rear, 2.5-3 deg camber front. front sway is at mid-stiffness setting, rear sway is at high-stiff setting, coilovers set per manufacturer, damping is level 3 front, level 4 rear. Running 35 psi on all 4 tires as this seems to be the sweet spot for my tires (potenza s-03 pole positions)
Old Jan 22, 2008 | 07:40 AM
mgtibbetts's Avatar
mgtibbetts
I should also mention there is a stillen s/c also, which adds weight to the front.
Old Jan 22, 2008 | 07:43 AM
Z1 Performance
Former Sponsor
what tires? what pressure? what toe? how much preload? what height? NA? FI?
Old Jan 22, 2008 | 08:04 AM
Motormouth's Avatar
Motormouth
^ lol...
Old Jan 22, 2008 | 08:09 AM
Z1 Performance
Former Sponsor
ok - well the s/c definitely is contributing to things since it adds, I'd imagine, over 100 lbs or so to the front end
here is a nice concise chart that should give you a good starting point on what to address
http://www.rogerkrausracing.com/Tech...verunder.shtml
Old Jan 22, 2008 | 03:22 PM
Kolia's Avatar
Kolia
245 front and 275 rear comes to mind as a wrong setup...
Old Jan 22, 2008 | 03:37 PM
ke0ki2k's Avatar
ke0ki2k
non-staggered ftw! its what all the JDM time attack cars run! lol
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
