cross drilled rotors
Old Jan 23, 2008 | 08:39 PM
youcantzme's Avatar
youcantzme
Default cross drilled rotors
i have a question if i want to get slotted crossdrill rotors, i need to get new brake pads?
Old Jan 23, 2008 | 10:18 PM
350ZTheStandard's Avatar
350ZTheStandard
That is what common sense says, you don't change the oil in your Z car with more used motor oil do u?
Old Jan 24, 2008 | 06:54 AM
gothchick's Avatar
gothchick
As long as you have it apart, might as well change it all out. You'll need to bed the new pads to the rotors.
Old Jan 24, 2008 | 07:43 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
No, your used pads will be fine on new rotors.
Old Jan 24, 2008 | 07:49 AM
NickRaine78's Avatar
NickRaine78
I hope ur joking.
If your old pads are worn they will not contact the rotor correctly which can cause problems later down the road. FOr the price of pads you should do it cause rotors cost a good amount.
Old Jan 24, 2008 | 09:02 AM
StopTechErik
Im not joking. Unless the pads are mostly worn down, there is no reason to change your pads for new rotors. Pads will very quickly mate with the new rotors, especially when a bed in procedure is performed.
Old Jan 24, 2008 | 09:05 AM
NickRaine78
You are right but in my experience, most people that have to replace their rotors are long overdue for pads. I kinda explained it wrong!
Better safe than sorry! Pads are cheap just buy em!
Old Jan 25, 2008 | 09:32 PM
z-u-later's Avatar
z-u-later
Originally Posted by NickRaine78
I hope ur joking.
Are you trying to argue with someone who works for Stop Tech!? What you're reading is a professional advise from someone who does this for a living . . .
Old Jan 26, 2008 | 07:47 AM
Kolia's Avatar
Kolia
Ah ! Party pooper!
This was getting fun to read! Aha!
Seriously, like Erik said, when replacing rotors or pads, it is not necessary to change everything or turn the rotors if they are still in good shape.
Old Jan 26, 2008 | 08:18 AM
teh215's Avatar
teh215
Bingo. I think this falls into the "While you're at it" category unless the pads are very new. If the OEM pads are still on there then definitely do it, if for no other reason than putting a pad on that is less dusty.
[/2¢]</2¢>
sales@czp
Sep 23, 2019 03:30 PM
Stevo Z
Oct 3, 2015 09:14 PM
_bit
Oct 2, 2015 07:49 AM
samansharif
Sep 25, 2015 12:31 PM
