stage 2 brake upgrade
Old Jan 24, 2008 | 07:55 AM
MrWatchDawg's Avatar
MrWatchDawg
Default stage 2 brake upgrade
I just got my stage 2 brake upgrade (stop tech cross drilled rotors, hawk pads, stainless steel lines, and motul) but ever since i got that done my car takes longer to stop?
now my old pads and rotors were pretty much gone but since i go this, seems like it just takes longer to stop
is it normal?
-Mo
Old Jan 24, 2008 | 08:08 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Even after warming up the brakes. I have the stage 2 as well, and mine seem to be a little better than stock.
I do realize that if I hammer the brakes right of the bat, they are a little slow. But then again, it has been months since I have driven the car as well.
Old Jan 24, 2008 | 08:33 AM
rcdash's Avatar
rcdash
Did you follow the bedding procedure?
Much of the change may have to do with the change in pads.
Some pads are designed for less initial bite, but also less fade over constant use. It's a tradeoff.
Old Jan 24, 2008 | 09:05 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
If it has Hawk pads, its not one of our true Stage 2 kits.
Doing a bed in procedure is critical though to get the best performance:
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Old Jan 24, 2008 | 09:36 AM
julian's Avatar
julian
if you could lock up your tires with your old setup, your new setup won't make you stop shorter. stickier tires will.
it's probably a difference in brake pad compound.
Old Jan 24, 2008 | 09:42 AM
___DJK___'s Avatar
___DJK___
definitely bed them in!
Old Jan 24, 2008 | 02:21 PM
HaNkYs_Z's Avatar
HaNkYs_Z
What pads come with the true stage 2 kit?
Old Jan 24, 2008 | 06:36 PM
StopTechErik
Axxis Ultimates are the pads provided with our stage 2 kits.
Old Jan 24, 2008 | 06:41 PM
Nexx's Avatar
Nexx
hawk pads have less bite then stock pads, that is what you are feeling. you'll get less dust though!
Old Jan 24, 2008 | 06:44 PM
MrWatchDawg
SOB lol i guess that is what i am feeling, kinda sucks because i was used to the car stopping with just the tap of the break now i have to actually push down!
-Mo
Old Jan 24, 2008 | 06:52 PM
Nexx's Avatar
Nexx
-Mo
yep, sux. i almost bought hawk because of the less dust characteristic but when i read about the horrible bite i passed.
Old Jan 25, 2008 | 08:57 AM
gothchick's Avatar
gothchick
+1
Yep, that's what mine came with.
Old Jan 25, 2008 | 03:58 PM
MrWatchDawg
i got it done at a local performance shop, i think he put it together piece by piece but i dont mine.
how are those pads though?
-MO
Old Jan 28, 2008 | 06:48 PM
QuicksilverZ33's Avatar
QuicksilverZ33
^ what hawk pads are you using?
Old Jan 28, 2008 | 06:51 PM
MrWatchDawg
hawk hps.
-Mo
EnjukuRacing
Sep 30, 2015 06:55 AM
