Lowering the Z
Old Feb 6, 2008 | 09:11 PM
George350Zss's Avatar
George350Zss
Default Lowering the Z
Pros and cons of lowering? I was on the verge of lower, had my friend and I ready to install but then I came across this forum and that is when I learned about camber kit and premature wear if I didnt get one. So now the cost of buying front and rear camber sets, along with alignment is putting me in over my head and now I'm not considering lowering the z at all. Instead I want to get a lip kit or get more bolt ons (HFCs), but then it comes back to lowering and whether or not the z would look good with a lip kit at its current stance. Help me out guys make the decision, all input would be great...
Old Feb 6, 2008 | 09:24 PM
_NIZMO_'s Avatar
_NIZMO_
search noob
Old Feb 6, 2008 | 09:34 PM
DraGonAlchemist's Avatar
DraGonAlchemist
having done 2 alignments on lowered g35's so far. .they both only needed rear camber kits. .the front was pretty much in the green so to say. .just the rear had issues on both cars. .
Old Feb 6, 2008 | 09:49 PM
George350Zss
Originally Posted by _NIZMO_
search noob
whats that supposed to mean? Hey thanks for the help though
Old Feb 6, 2008 | 09:59 PM
LT_350Z's Avatar
LT_350Z
he means theres a lot of info on this site jus hit the search button and all ur answers will be there excuse his unkindlyness
Old Feb 6, 2008 | 10:13 PM
Escobar's Avatar
Escobar
it means that question has been asked a thousand times. try browsing a couple of threads when you type in "lowering the Z" with the search feature.
Old Feb 6, 2008 | 10:14 PM
finalforce's Avatar
finalforce
Looks wise, IMO, close the gap between tire and fender as much as possible. Z's are big and bulky out of the factory. You add a lip or body kit, it will look heavy and narrow on stock height. It looks even worse when you put big wheels, then it looks like a rolling block.....my thoughts.
Old Feb 6, 2008 | 10:17 PM
Escobar's Avatar
Escobar
https://my350z.com/forum/showthread....lowering+the+Z
the second one has the exact same title as yours
Old Feb 6, 2008 | 10:34 PM
George350Zss
thanks, kinda new to the sight, so didnt know better. Well i found my answer, all you need is the rear camber and toe bolt so I think i should be ok now.
Old Feb 6, 2008 | 10:45 PM
ALO8's Avatar
ALO8
spc rear camber kit is the least expensive
Old Feb 7, 2008 | 03:16 AM
DraGonAlchemist
yeah the 2 G35's i did in fact both guys had bought the SPC's. .
but over at www.hopupracing.com i believe there is one cheaper kit by ICHIBA. .$155. and HUR $129..i could be wrong though
camber section~http://hopupracing.com/cambertoearms.html
Old Feb 7, 2008 | 10:40 AM
Escobar's Avatar
Escobar
Old Feb 7, 2008 | 11:48 AM
George350Zss
i just got a pair from super autobacs yesterday 165 each
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
