SPC Field Rework Notice - 72120 & 72125 Control Arms Z/G35
Old Feb 19, 2008 | 04:19 PM
Pokémon's Avatar
Pokémon
Default SPC Field Rework Notice - 72120 & 72125 Control Arms Z/G35
Anyone else get this letter?
To: SPC Customers
Specialty Products Company is issuing a Field Rework Notice for part numbers 72120 and 72125 front upper control arms for the 350Z and G35 models.
Under extreme conditions the nut of the ball joint stud could pull through the spindle causing a separation of the upper control arm from the spindle and a sudden loss of control.
If the kit in question has been installed reusing the OE flanged lock nut no further action is required. If the kit was installed with the provided castle nut, then the enclosed washer should be installed following the included instructions. If you prefer to have a professional installer do the work, Specialty Products Company will reimburse up to $25.00 for work at a licensed garage. The original bill from the garage must be submitted to Specialty Products with the instruction sheet and a letting requesting reimbursement.
Please contact SPC customer service at 800-525-6505 if you have any questions on this.
Sincerely,
I'm wondering if I should even bother putting just a washer under the ball joint.
Old Feb 20, 2008 | 06:59 PM
98Ekhatch's Avatar
98Ekhatch
yep just got mine in the mail today...
Old Feb 21, 2008 | 06:39 AM
mdracer76's Avatar
mdracer76
Bump.. I have not recieved etter yet.. I will have to double check my install too
Old Feb 21, 2008 | 08:24 PM
VIZAGE's Avatar
VIZAGE
I started a thread on this not to long ago, with hardly no replies. But I noticed this when first installing the nut. When I went to tighten it, it just pulled threw the spindle. I instantly knew that the stock one would work, after I made sure the threads where the same.
But I haven't seen a letter. Doesn't matter for me though.
Old Feb 22, 2008 | 12:00 PM
Pokémon's Avatar
Pokémon
I actually got around to put the washers in yesterday since I had some spare time to kill. I honestly didn't think it's necessary for daily street driving.
The only problem I encountered during the install was that the washer they provided was a little too thick. There wasn't enough room for the cotter pin. I was only able to fit one side of the cotter pin through.
Old Feb 22, 2008 | 05:34 PM
terrorist22's Avatar
terrorist22
Mine are just sitting in my room (not sure if I want to install them), but thanks anyways
Old Feb 22, 2008 | 07:26 PM
QuadCam's Avatar
QuadCam
I just got the letter and the washers today.
I noticed that when I torque the nut down against the spindle that the castle nut was creating some aluminum shavings. I didn't think much of it, but I'll either install these washers or use the factory nuts.
Old Feb 25, 2008 | 01:37 AM
RanFerr_350z's Avatar
RanFerr_350z
yah i got the letter a week ago, but i don't feel like paying someone to put washers on and i don't have any time to put them one either.
Old Feb 25, 2008 | 10:36 PM
Pokémon's Avatar
Pokémon
They'll reimburse you $25 if you provided the receipt. Regardless, I just did it myself. Quick half hour.
Old Feb 27, 2008 | 07:54 AM
QuicksilverZ33's Avatar
QuicksilverZ33
Are SPL Parts and SPC the same company?
Old Feb 27, 2008 | 10:32 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
SPL PARTS and SPC Performance are totally different companies
Obadabot
Jun 18, 2023 11:31 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
