Brake fluid shelf life
Old Feb 27, 2008 | 03:46 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default Brake fluid shelf life
Just wondering if someone know what the shelf life of a sealed bottle of brake fluid usually is?
Thanks
Old Feb 27, 2008 | 06:54 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Anyone?
Old Feb 27, 2008 | 07:02 AM
dkmura's Avatar
dkmura
General & DIY Moderator
As long as the bottle is sealed- no air or moisture getting in- a DOT 3/4 silicone based brake fluid should last in storage for many years. Maybe you should mention what brand and type you're considering using. Also, if it's real old, it may not be compatible with your Z.
Old Feb 27, 2008 | 08:01 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
It's dot 5.1 ferodo brake fluid. It's not silicone based. Only Dot 5 are normally silicone based.
Old Feb 27, 2008 | 05:34 PM
Eazzy's Avatar
Eazzy
If the cap is tight, it will last a long time----The alcohol based fluids 3-4 do what alcohol does---attract moisture. Keep it tight
samansharif
Sep 25, 2015 12:31 PM
