? for those who replaced brakes with OEM Brembos
Old May 16, 2008 | 08:52 AM
  #41
DavesZ#3's Avatar
DavesZ#3
Originally Posted by SOLO-350Z
Dave, how do you keep it from leaking? I heard it wants to leak at the cap when it has pressure. I ordered mine should be here soon.
If you have the model with the universal adapter, it's hard to stop the leaks but it can be done. You really have to crank down on the chains to get it tight.
The Nissan specific adapter fits in place of the normal reservior cap and it doesn't leak pressure at all.
Old May 16, 2008 | 09:13 AM
  #42
Carbon-Z's Avatar
Carbon-Z
Sleeps in 350Z
Per the place I talked too they said there was no specific adapter for Nissans and we had to use the Universal. GRR!
Old May 17, 2008 | 02:56 PM
  #43
619350z's Avatar
619350z
I have a quick question I'm planning to do the same thing to my car (swap the stock brakes to the OEM brembo brakes) do they only come in red or do they have gold/bronze ones aswell?????? cause to paint them is a pain.
Old May 17, 2008 | 03:13 PM
  #44
DavesZ#3's Avatar
DavesZ#3
http://www.jscspeed.com/universal/products/motive.htm
Get #0107 for the Z (Nissan).
Old May 17, 2008 | 03:14 PM
  #45
DavesZ#3's Avatar
DavesZ#3
The OEM Brembos for the Z are gold. OEM Brembos for some other cars are red, i.e. Mitsubishi WRX.
Old Jun 13, 2008 | 08:33 AM
  #46
Hydro_Z's Avatar
Hydro_Z
I'm thinking of doing this swap on my friends' base 2007 Z. Do you guys think there will be any issues?
Old Jun 13, 2008 | 10:31 AM
  #47
DavesZ#3's Avatar
DavesZ#3
Other than the bleeding issue, it's a pretty straight forward process.
Old Jun 13, 2008 | 12:40 PM
  #48
Hydro_Z's Avatar
Hydro_Z
Cool thanks!
Old Jun 13, 2008 | 01:36 PM
  #49
35Z's Avatar
35Z
Question Brembo Brake Booster Specs?
[QUOTE=SuperBlack350z]this was how mine felt when i used the OEM non brembo master cylinder. Right away after i installed my brembo master cylinder that i obtained from the dealer, the feeling felt normal again and the pedal was short.
Does anyone knows of the Brembo Brake Booster spec? Can it be adapted to the non-brembo master cylinder?
Old Jun 23, 2008 | 09:00 AM
  #50
Candy_man's Avatar
Candy_man
Edited: Already covered.
Old Jun 23, 2008 | 09:02 AM
  #51
Candy_man's Avatar
Candy_man
107 fits right on the Z
Old Sep 29, 2008 | 10:36 PM
  #52
avandss's Avatar
avandss
[QUOTE=35Z;5893855]
so pissed just passssed 6 hours installing my brembos everything went smooth I don’t have a pressure system but I had my friend pump 5 times then keep it down! I did the right sequence and bled it 3-4 times!
My pedal feels likes manure! Nobody covered the braked booster issue? Is it the same part?
Do I need to go under my car again and pump away like crazy 10 more times?
the reason I ask is because I don’t see how air would get stuck near the booster since I changed one caliper at a time
Old Sep 30, 2008 | 02:59 AM
  #53
DavesZ#3's Avatar
DavesZ#3
It has nothing to do with the booster. Once you disconnect a line, air gets into it and bubbles work their way back up into the ABS pump.
As I described above, I bled mine over and over and it was still soft. As soon as I used the pressure bleeder, a couple of huge air bubbles came out when bleeding the fronts.
Old Sep 30, 2008 | 04:21 AM
  #54
z-u-later's Avatar
z-u-later
More reason why I took mine to the shop to get my Brembos installed. They always do it right -- the first time. I just didn't have the time nor the tools to DIY. Once installed, you'll be happy with the swap, especially if you like to track your car.
Old Sep 30, 2008 | 07:15 AM
  #55
avandss's Avatar
avandss
stupid question, a pressure bleeder is better then 2 ppl and the push peddal trick?
if so i will order one right away!
Old Sep 30, 2008 | 08:17 AM
  #56
DavesZ#3's Avatar
DavesZ#3
Anything is better than the 2 person push pedal trick.
I guess because the power bleeder keeps a continuous pressure and flow of fluid through the system, it is better in getting the trapped bubbles out. Even with the power bleeder hooked up, it's not a bad idea to go push the pedal occasionally to make sure the master cylinder is bled too.
Old Sep 30, 2008 | 10:10 AM
  #57
avandss's Avatar
avandss
i hope canadian tire has this, i cant stand my car anymore! lol
btw i will post pics of where i got my brembos later tonight...u have to see this
Old Oct 8, 2008 | 08:13 PM
  #58
avandss's Avatar
avandss
they dont ship to canada!!!! want to sell me yours????
Old Nov 3, 2008 | 05:30 PM
  #59
VQdriver's Avatar
VQdriver
do i need the motive power bleeder to successfully bleed the master cylinder? i must have spent an hour bleeding and the pedal is still a bit soft....yay for me, gotta do it again OR buy the motive bleeder!
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
