Koni install on a G sedan. Strut stud supposed to stick out this much?
Old Mar 28, 2008 | 12:54 PM
Jeff92se's Avatar
Jeff92se
Default Koni install on a G sedan. Strut stud supposed to stick out this much?
This is using what I think are Z strut tops on the Konis. I even took apart one of my G struts to compare the strut tops. Looks diff yes. But dimensionally, they look to be identicle. Especially the part that the bolt/shaft goes though. Pic. Left bare Koni, Middle is assembled, Right is stock G assembly.
Old Mar 28, 2008 | 08:59 PM
Gsedan35's Avatar
Gsedan35
Yes it is normal. It's a pain to have to spin past all those threads, but when you run a setup that has high preload levels, you'll appreciate they are their.
Old Apr 3, 2008 | 12:27 PM
Jeff92se's Avatar
Jeff92se
Thanks. Apparently Konis are a rarity.
