WP Pro 8pot Front / 6 Pot rear Brakes, Install and Review.
Old Apr 7, 2008 | 11:59 AM
NoahzBurnt's Avatar
NoahzBurnt
'bought friggen time u got some brakes!!!!
Old Apr 7, 2008 | 01:09 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by mdracer76
Damn I love those....
Old Apr 7, 2008 | 03:58 PM
OnADimePBS's Avatar
OnADimePBS
Looking very nice! Are those directional veined rotors?
Old Apr 8, 2008 | 08:06 AM
mdracer76's Avatar
mdracer76
Yup. Isn't it a standard now on performance braking applications? I've seen a few different styles of venting/veining up and including aptly named vented/veined rotors called the 'Kangaroo Paw' pattern from DBA (Disc Brakes Austrailia).
As you can see on the WP Pro rotors, the channels and the rotation indicator.
Old Apr 8, 2008 | 08:25 AM
NA350Z's Avatar
NA350Z
Sick brakes!
Old Apr 8, 2008 | 09:15 AM
OnADimePBS's Avatar
OnADimePBS
Yea that's why I was asking, I thought you had your rotors on the wrong way for a second.
Old Apr 8, 2008 | 09:26 AM
buzzardmountain's Avatar
buzzardmountain
Show-off........
Old Apr 8, 2008 | 11:56 AM
mdracer76's Avatar
mdracer76
Thanks NA350Z
lol.. no worries!
Originally Posted by buzzardmountain
Show-off........
LOL. well.. I hope to get some time tp post a picture by picture write up of the install. Car is still on jack stands in my garage. Rain has prevented me from taking it out to bed the brakes in.
Old Apr 8, 2008 | 05:30 PM
mdracer76's Avatar
mdracer76
So.. Install was pretty strait forward. I would recomend that if you are not familiar with changing your own brake pads and rotors, to not attempt this install and seek a reputable installer.
On to the pictures!
1: Jack up your car / Get out your tools / and observe your small, cute, stock brakes
notice the size diff in rotors..
2: Remove the 2 bolts holding your pads, then remove the next 2 bolts that hold the caliper to the hub assembly. Slide the calper off to the side. I dangled mine from the brake line.. normally you don't want to do that since you'd be re-using the lines, but since this kit came with stainless lines.. it did not matter.
Clean the hub face
3. The step that will save you an hour. Note in this next image the orientation of the new bracket. add lock-tight and torqe to spec as outlined in paperwork that came with the brakes.
4. Place the rotor on the hub, and rotate it. Note any rubbing on the heatshield sounds and bend / trim until you hear nothing.
you can hold the rotor on with your lug nuts.
5. mount the caliper to the new bracket. do not torque these on yet (as per the instructions)
6. load the pads!
7. Remove the old caliper and brake lines and install the SS line to the hardline. Be sure to route the lines similar to the path of the stock lines.
fronts ready to bleed:
8. Rears.. Break out the cutting wheel for extra duty!! LOL. OK.. so.. remove your old pads / calipers just like the fronts.
9. remove the rotors. you can be a sissy and tap it with a rubber mallet and try and save your rear rotors..or you can do what I did and take out some oppressed aggression on them. (i.e. beat with large hammer until free)
**the later is more fun.
9.5 you could also losen the drum brake using a flat head screw driver in the access window on the rotor.
10. Rotor is off.. time to cut the dust shield. It has a li that must go!
10A yes . I know I am fat.
10B yes.. I know I am balding.
10C Cutting tool provided by FunctionTuned LLC (Thanks Dave!!!!!)
11. A clean hub is a happy hub
12. TIME SAVER ALERT. Note the orientation of the bracket!
13. see that little wheel thing there? Thats how you adjust the drum brake.
make sure you orient THIS HOLE in the new caliper to it, or all the kids will laugh at you!
14. mount new caliper
15. install pads.
16. Remove brake line and install Stainless line.
Rears should now be ready to bleed.
17. Remember to bleed in this order:
1 Rear passsenger
2 Rear Driver
3 Front Passenger
4 Front driver
18. Bed the pads in according to the instructions. I have not yet, since its been raining here for the last few days.
hope you enjoyed my write up! I'll update this thread with some track info ( I also ordered some track pads) and my driving impressions! Enjoy!
If I did not already say, I'll say again
BIG Thanks to Dave @ FunctionTuned for letting me borrow some tools, and being great tech. support.
Randy, for help installing, and picha's! Brent, For being a bleeder, best damn bleeder you can find.
Old Apr 8, 2008 | 06:25 PM
kcobean's Avatar
kcobean
Those are simply amazing. And isn't it satisfying wrenching on your own car?
Old Apr 8, 2008 | 10:53 PM
Chebosto's Avatar
Chebosto
a few observations.
1. wear some better eye / face protection when using rotary tools so close to your face. kick back and/or shards flying is no good. eye glasses dont count.
2. did u pop a stiffie after the install or are your jeans like super weird in this pict:
3. waiting for driving impressions.. that color is so awesome with your color scheme on the car
Old Apr 8, 2008 | 11:05 PM
aloh's Avatar
aloh
Originally Posted by Chebosto
a few observations.
ummm...what made you look in that general area?
Old Apr 8, 2008 | 11:24 PM
Sensi09's Avatar
Sensi09
Works Concepts
The color of those calipers are really nice, but I think it would be better if it didn't say 6/8 pot on them.
Like a lot of people, I've never heard of WP. How does the quality and pad selection compare with other brands? Does WP have the same quality as brembo and stoptech or is it more along the lines of rotora and wilwood?
Old Apr 9, 2008 | 04:48 AM
mdracer76's Avatar
mdracer76
a few observations.
You looking at my junk?
Thanks C!
Old Apr 9, 2008 | 08:36 AM
fairladyinit's Avatar
fairladyinit
money
Old Apr 9, 2008 | 08:44 AM
wheatz's Avatar
wheatz
Looks sweet... the orange is a nice touch!
I noticed this kit is from a Taiwan company so I wonder if they're made at the same factory as Stoptech since Stoptech calipers are also made in Taiwan.
Chebosto -- Seriously!?!?! You get married last month and you're already checking out another dude's junk!
Old Apr 9, 2008 | 08:49 AM
will350z's Avatar
will350z
What can you say, I guess Chebosto just can't get enough...
Old Apr 9, 2008 | 08:51 AM
  #38
SpoilsofWar's Avatar
SpoilsofWar
You may be fat and balding, but at least you now have some bad *** brakes.
Old Apr 9, 2008 | 10:07 AM
  #39
Chebosto's Avatar
Chebosto
hey. i notice the little things in pictures..
Old Apr 9, 2008 | 10:14 AM
  #40
buzzardmountain
Looks great Mike.....and no I'm not talking about your package.....
