ichiba vs. spc rear camber kit
Old Apr 16, 2008 | 08:47 PM
JJ19's Avatar
JJ19
Default ichiba vs. spc rear camber kit
who has what and is it worth it? also, is it better to do an alignment before/after installing wheels spacers?
Old Apr 16, 2008 | 10:11 PM
terrasmak's Avatar
SPC comes with the toe bolts, Ichiba does not. Other than that they are pretty much the same. Alignment, well technically the spacers dont matter, but its a good idea to get all your stuff installed to you normal driving config before alignment.
Old Apr 16, 2008 | 10:21 PM
Nexx's Avatar
Nexx
so what about the $50 camber kits off ebay?
Old Apr 18, 2008 | 08:31 AM
JJ19's Avatar
JJ19
so with the ichiba, i can't adjust the toe???
Old Apr 18, 2008 | 09:17 AM
WhiskeyHotel's Avatar
WhiskeyHotel
You can adjust the toe a little bit with the stock arms - just maybe not enough, depending on your drop/camber adjustment. Toe bolts give you that extra adjustment you may need.
Old Apr 18, 2008 | 10:56 AM
InZomniac's Avatar
InZomniac
Align after spacers
Old Apr 18, 2008 | 03:29 PM
redlude97's Avatar
redlude97
Are you sure about that? The pics on ebay show the toe bolt
Old Apr 18, 2008 | 04:13 PM
WhiskeyHotel
It does look like you get the toe bolt, too. Seller just doesn't mention it.
Old Apr 18, 2008 | 04:30 PM
terrasmak's Avatar
Well if you go to the www.ichibausa.com , there is no mention of toe bolts. But it does look to include new bolts to attach your camber arms to your car.
Old Apr 18, 2008 | 06:31 PM
redlude97's Avatar
redlude97
Those are the toe bolts, they just happen to put them on the end of the camber arm. Take a look under your rear and you'll see that they use they same bolts as your toe adjustment
Old Apr 18, 2008 | 09:23 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
SPC.
came with toe
Old Apr 18, 2008 | 09:55 PM
Gsedan35's Avatar
Gsedan35
The ichibausa.com pics show the oem cam bolt that both the oem lower control and oem camber arms have, not the oversized cams that make up the SPC toe cam bolts.
I have alway's felt that the SPC rear kit with toe cams is the way to go. However, I bought the SPL camber arm kit with SPC toe cam bolts because IMO their arm's more robust construction is worth the increased cost.
I know you understand this, but to everyone else. When you dial out greater level's of negitive camber then the oem system can do, your effecting toe more then the oem toe control system can do. So, if you need camber arms, you need the toe cam bolts to.
Old Apr 18, 2008 | 11:20 PM
JJ19's Avatar
JJ19
looks like i'll be going with spc to be on the safe side. thanks for the info.
Old Apr 19, 2008 | 09:21 PM
redlude97's Avatar
redlude97
I guess upon closer inspection you are right, those aren't the spc toe bolts. The bolt isn't offset far enough on the washer compared to the spc so it must be the OEM bolt
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
