alignment question
Old Apr 29, 2008 | 07:43 AM
JJ19's Avatar
JJ19
Default alignment question
if i get an alignment done and wait a couple of days to install rear brake pads, will it mess up my alignment?
Old Apr 29, 2008 | 08:16 AM
terrasmak's Avatar
If you screw up your alignment doing pads, you really shouldnt be touching a wrench to a car.
Old Apr 29, 2008 | 11:23 AM
Spoiled Z's Avatar
Spoiled Z
+1 LOL
Old Apr 29, 2008 | 08:16 PM
stuntman's Avatar
stuntman
Your bakes have nothing to do with your alignment. All you're doing is taking you wheel off, pulling the pads out and replacing them, then putting the wheel back on.
Old Apr 29, 2008 | 09:08 PM
JJ19's Avatar
JJ19
i don't work on cars hence it might seem dumb to ask my question but there is never a stupid question. its a way how to learn to do things. all in all, thanks for keeping it real.
Old Apr 29, 2008 | 09:37 PM
stuntman's Avatar
stuntman
Sorry if I came off poorly. I was just listing the basic steps necessary to replace your pads and how they dont affect your alignment. I agree, you have to start somewhere, and you get that knowledge by asking.
Good luck!
Old May 1, 2008 | 04:33 AM
350zion's Avatar
350zion
Professional
But first u have to remove the flux capacitor to access the hyper drive thus removing the velocity stack! Eer yea sounds easy! Lol u should have no problem doin this. After a few times it will be a piece of cake. Good luck,,,
Old May 1, 2008 | 07:23 AM
Q45tech's Avatar
Q45tech
Even worse an Alignment is actually a static MISALIGNMENT designed to compensate for the pressure and bending that results from the car moving down the road at 60 mph [STRAIGHT].
The designers actually measure what happens at 60 mph and create a set of MISALIGNMENT NUMBERS that correct things as much as possible to minimize fuel consumption [camber and toe].
Unfortunately as the suspension ages and the rubber gets deformed new factory MISALIGNMENT specs may no loger be ideal.
Old May 1, 2008 | 12:15 PM
350zion's Avatar
350zion
Professional
...WERD!
Old May 1, 2008 | 06:25 PM
turismo's Avatar
turismo
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
Alexreyes
Sep 30, 2015 11:30 PM
