Clunking noise from rear Coilovers over bump
Old May 1, 2008 | 06:58 PM
350zrn35's Avatar
350zrn35
Default Clunking noise from rear Coilovers over bump
how many of you have a clunking noise problem after a coilover set is installed?
Symptom: when the car be driven at a low speed over a bump, you hear a clunking noise from the rear of your car.
SOLUTION:??????
Old May 1, 2008 | 07:24 PM
JETPILOT's Avatar
JETPILOT
Tighten the nut on the top of your coil over. You have to use an impact wrench or else the piston will spin as well.
JET
Old May 1, 2008 | 07:54 PM
350ZTheStandard's Avatar
350ZTheStandard
Yeah what Jet said, i had the same problem and that is how I fixed the issue
Old May 1, 2008 | 10:47 PM
350zrn35's Avatar
350zrn35
thanks but how do I use an impact gun at the back?
Old May 1, 2008 | 10:51 PM
350ZTheStandard
ON the top of the coilover, inside the car in the hatch area, I would also tighten the adjusting nuts on the actual coilover with the spanner wrenches
Old May 1, 2008 | 11:17 PM
JETPILOT's Avatar
JETPILOT
You have to remove the rear coilovers to tighten the nut. Sucks... but that's the only way.
JET
Old May 2, 2008 | 05:37 AM
FlyingSquirrel's Avatar
FlyingSquirrel
I did mine (impact gun on top nut), then 1000 miles later (last week) the **** starts to rattle again. what gives? Probably the joint that is on the ball? Grease it? Out of ideas and I know the top is tight. Also tightened the bottom with a tein supplied wrench.
Old May 4, 2008 | 05:01 PM
350zrn35's Avatar
350zrn35
ok may be I will give that a try.
But it is a pretty prominent clunking noise, NOT ticking/a simple rattling noise.
Any more idea?
Old May 5, 2008 | 01:11 PM
nkohler's Avatar
nkohler
I took a thin piece of rubber sheet found from the plumbing section of your favorite hardware store and cut it out exactly the shape of the top of the rear strut hat and I no longer have clunking noises. It must have been from the metal on metal at the top of the strut. I tried tightening up the bolts up there but it did not seem to help. Some may say that the thin piece of rubber I used will not give the direct feedback, but it will be very minor.
looks like this, but its a little bit thinner:
Old May 6, 2008 | 10:06 PM
350zrn35's Avatar
350zrn35
I think it has something to do with the rear spring and coilover...any thoughts?
Old May 7, 2008 | 08:16 PM
Gsedan35's Avatar
Gsedan35
You may be suffering with the lower shock mount bushing issue that a few truecoilovers users have experienced. While many truecoilover owners will mention that they don't have the issue, this doesn't help the owners that do. Consider having Nismo lower shock mount bushings pressed in or consider a custom made bushing replacement.
You have Stance coilover, correct?
Old May 8, 2008 | 01:41 AM
350zrn35's Avatar
350zrn35
Thanks for your input.
Do you know what causes that? stock ones too soft?? I had a set of Bilstein sport tuned shock and spring kit on before, it didn't make that noise. And now I have OHLINS on.
Any more idea, ppl?
Old May 8, 2008 | 07:29 AM
Gsedan35's Avatar
Gsedan35
Any more idea, ppl?
Ohlins,...scratch what I said above, you don't have a true coilover in the rear.
You need to look at the usual suspects concerning the noise.
Go back and check every single thing you would have loosened and tightened in the install process, on the suspension, damper and seperate spring assembly. Also check your rear sway bar end links and the bolts they attach with.
Did you buy the used Ohlins setup from jerjerboy?
The bilstein setup you had, that was the JDM dealer optional kit, correct?
Old May 8, 2008 | 01:34 PM
350zrn35's Avatar
350zrn35
I will check. No I donno that member, I got my brand DFV brand new. I think it has something to do with the rear springs, since I only hear that clunking noise when they are being compressed. Those rubber pieces that can be put onto the coils might eliminate the noise.
And yes, the Bilstein is JDM. I have a couple suspension sets lying around and I am thinking of selling them if anyone is interested.
Old May 8, 2008 | 02:40 PM
dklau33's Avatar
dklau33
You have the cusco zero 2 rubber mount setup right? So do I and I have the rear clunking noises. I already tightend the crap out of the top mount nuts but that didn't do anything. I'm going to have to try this sometime.
Old May 9, 2008 | 05:27 PM
425skyline's Avatar
425skyline
I have this noise with my BC coils in the back. My mech put some radiator gaskets over the coilovers (they are rubber and are almost the same shape as the mount). It made the noise worse. However, he did say that the contact between the shock mount up top and the actual pillow ball mount is what is most likely the culprit of the noise, since he could see that wear on the mount of the shock had only partially appeared. The shock mount is a circle, and we could only see about 3/5 of that circle starting to rub down on the pillow ball mount area, which is painted gold.
Basically, poor contact. I'm going to try and get some thicker rubber and doing that custom cutout that someone suggested.
The alignment shop that corner balanced my car and all that fancy stuff after I installed all my stuff said that some coilovers just make noise like this but he didn't disassemble the shock from the car to determine the true problem.
Old Sep 16, 2010 | 02:41 PM
Aussie Mick's Avatar
Aussie Mick
Thanks for the advice, i pulled the my megan track coilovers back off, put dyna mat on top and impact driver on the nut and no more noise.
Old Sep 21, 2010 | 07:08 AM
Spoiled Z's Avatar
Spoiled Z
I have the same problem but I have it on then front right coilover. What can I do to fix the clunking noise over bumps and my front damper ***** won't turn at all. Only driven the car for 6 miles after the install. I inspected when I first got it and try were working fine.
Old Sep 24, 2010 | 08:41 PM
Aussie Mick
PMed.
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
