6 piston vs. 4 piston Stoptech
Old May 3, 2008 | 12:59 PM
JETPILOT's Avatar
JETPILOT
Default 6 piston vs. 4 piston Stoptech
What is the advantage of the 6 piston 355mm stoptech front kit over the 4 piston 355 front kit?
JET
Old May 3, 2008 | 01:03 PM
saberphx's Avatar
saberphx
looks 6>4
Weight 6<4
Better/slower pad wear 6>4
Better brake balance/bias 6>4
Just stating the obvious
Old May 3, 2008 | 01:14 PM
thinking's Avatar
thinking
Years ago, StopTech proclaimed anything more than 4 piston was unneeded, and that everyone putting out 6 piston designs were doing so for purely marketing reasons.
Later, (not sure how many months/years) they began producing a 6 piston caliper and stated that the only advantage was increased brake pad longevity.
Old May 3, 2008 | 01:39 PM
JETPILOT's Avatar
JETPILOT
Better brake bias? All the Stoptech calipers have the same bias from front to rear.
So I guess the larger pad wears longer. Hmmmm... not much of an advantage given the added cost of the 6 piston. Thanks!
JET
Old May 3, 2008 | 05:57 PM
Changvi's Avatar
Changvi
Amen....thank goodness i went with 4 pistons..
Old May 3, 2008 | 06:32 PM
r_seng's Avatar
r_seng
piston size.
Old May 4, 2008 | 05:30 PM
Chebosto's Avatar
Chebosto
having had both the 4 piston and now the 6 piston in the front,
both perform nearly identical.. the 4 piston caliper has a slight advantage of having more pad selection, but the 6 is supposed to wear better-
the 6 piston is slightly narrower in width, a little better for wheel spoke clearance, but looks pretty damn good when compared to the 4.
Old May 5, 2008 | 09:20 AM
Jeff92se's Avatar
Jeff92se
Originally Posted by saberphx
looks 6>4
Weight 6<4
Exactly how is the 6>4 in the brake bias category?
Old May 6, 2008 | 11:33 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
+1, the ST40 caliper has the same torque output of a ST60 caliper.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
