parking brake
Old May 13, 2008 | 07:59 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default parking brake
how do you adjust the parking brake on an 06? mine is getting loose even at the highest level.
Old May 14, 2008 | 05:34 AM
Chad68's Avatar
Chad68
Subscribing... because I have heard of different methods/theorys/myths.
Old May 14, 2008 | 06:38 AM
Jason333's Avatar
Jason333
hi
I think you can adjust the cable at the console, or you can pull the rear discs and adjust them at the top spindle little piece. (push the spring up so you can spin it)
Old May 14, 2008 | 06:45 AM
terrasmak's Avatar
There is no access for that on the 06 unless you pull the console. The other way is to pull the rear wheels and use the adjuster thru the drum.
Old May 14, 2008 | 12:17 PM
VO...'s Avatar
VO...
Administrator
+1. I believe it's a little rubber plug on the face of the drum, I could be wrong though. You pull it off and will have access to the adjustment **** inside the drum. You have to remove the wheels though...
Old May 14, 2008 | 01:57 PM
Ilov350ZEE's Avatar
Ilov350ZEE
pics. would help a lot. thanks for the input guys
samansharif
Sep 25, 2015 12:31 PM
