Pic of Installed Powerslot rotors please!
Old May 15, 2008 | 11:30 AM
UMW350Z's Avatar
UMW350Z
Default Pic of Installed Powerslot rotors please!
I installed powerslot rotors last week based up the instruction from powerslot but I am still not sure of the correct way the slots go. Before someone tells me "look at the vanes"...i already did, they are not directional vanes for this specific rotor. I took them out of the box and did not take not of which was left and which was right...apparently they make a difference according to Stoptech. They also plated over the marking which says L or R on the rotor. Could someone post a pic of POWERSLOT rotors installed correctly so i can confirm??
Thanks!
Old May 15, 2008 | 12:10 PM
SpeedRcr's Avatar
SpeedRcr
mine were marked l and r
Old May 15, 2008 | 12:59 PM
UMW350Z's Avatar
UMW350Z
Not mine...would you mind taking a pic? I will post mine tonight and you can tell me if they are right
Old May 15, 2008 | 01:16 PM
Chad68's Avatar
Chad68
From what I have heard if the veins are not directional it doesn't matter which way the slots go.
Maybe stoptech says it matters because their veins are directional?
Old May 16, 2008 | 07:25 AM
UMW350Z's Avatar
UMW350Z
My slots go in the same direction as this picture (these are not my brakes, but only an example of the way the slots go.
http://www.ratemynissan.net/showcar.php?carId=838
Thanks guys!
Old May 16, 2008 | 11:04 AM
UMW350Z's Avatar
UMW350Z
bump
Old May 16, 2008 | 11:07 AM
SlideFox's Avatar
SlideFox
The brakes on the car in the link are correct. You don't want the veins to point towards the caliper when going forward.
Old May 16, 2008 | 11:21 AM
UMW350Z's Avatar
UMW350Z
correct for specifically the Powerslot rotors, right?
Old May 16, 2008 | 11:29 AM
SlideFox's Avatar
SlideFox
I believe so. I had powerslot rotors on my '01 Honda Accord, and the veins pointed away front the caliper when moving forward.
Old May 16, 2008 | 11:35 AM
SlideFox's Avatar
SlideFox
Here is the technical answer....
Slotted rotors are used to put brake bust and heat away from the brake pad under clamping pressure. The slots angle out towards the edge of the rotor; therefore pulling heat and debris from the center. If it was backwards the the heat would be going towards the center of the rotor.
Old May 16, 2008 | 11:48 AM
UMW350Z's Avatar
UMW350Z
I have seen some cases where the slots are reversed from this pic because of the cooling vanes within the rotor. I'll ask MRC when it goes under the knife next week, I'm sure they have done PS rotors beefore.
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
