Allignment sheet
Old May 20, 2008 | 04:45 PM
AVmagneticZ's Avatar
AVmagneticZ
Default Allignment sheet
so i just got an allignment done after i put on my gf210 springs. im running 9.5f 10.5r 19 inch wheels with +12 offset all around. just wondering if all this looks semi normal, not running a rear or front camber kit either all stock still.
front left: spec range:
camber- (actual -1.6) (before -1.6) -1.3 to 0.2
caster- (actual 8.9) (before 8.9) 7.4 to 8.9
toe- (actual 0.05) (before 0.07) 0.00 to 0.10
front right:
camber- (actual -1.8) (before -1.8) " "
caster- (actual 8.8) (before 8.8)
toe (actual 0.06) (before 0.08)
rear left:
camber- (actual -2.2) (before -2.4) -2.1 to -1.1
toe- (actual 0.09) (before 0.05) 0.06 to 0.14
rear right:
camber- (actual - 2.2) (before -2.6)
toe- (actual 0.09) (before 0.19) " "
camber is maxed out he says, and yah just seeing if that looks right there are some more numbers here on this sheet but i dont have a scanner and they are all in range anyways. so i notice the front left and front right camber is off by .2 is that a big deal? and this is as close to spec as possible they said
Old May 20, 2008 | 05:32 PM
Spoiled Z's Avatar
Spoiled Z
Have another alignment done in about 2 weeks those numbers will still change. But you need rear cambers from the look of it possibly front cambers as well.
Old May 20, 2008 | 05:59 PM
roast's Avatar
roast
it doesn't matter if the camber is off a little from left to right... but your camber is out of spec all the way around... is it a problem? how often do you want to change tires?
Old May 20, 2008 | 07:20 PM
AVmagneticZ
i cant make the camber to be positive anymore in the rear or i will probably rubb. its cutting it damn close right now. the fronts can probably be more positive just require aftermarket camber arm. with the front im only .1 which is nothing away from spec range. so the rears are fine i guess, only front is possible
Old May 20, 2008 | 07:23 PM
AVmagneticZ
and the springs have been installed for 2 weeks now...and just today i did the allignment, you think it will stil change?
Old May 21, 2008 | 12:21 AM
unpluggedk's Avatar
unpluggedk
looking at the spec, it seems a lot like mine.
it is not off by a great measure and as long as you do regular tire rotations, you should be fine <imo >
what i am planning to do is after 3 or 4k miles,
take it to the alignment shop and rotate tires + re-align.
most of the shops will do tire rotations for real cheap or free with alignment if you ask.
they will still charge the alignment unless you went to firestone lifetime align or similar. (then again, firestone never gets it right --a so kinda pointless imo unless you plan to change setup often enough).
Old May 21, 2008 | 04:58 AM
Spoiled Z's Avatar
Spoiled Z
Nah but if I were you I would invest on some camber front and rear arms unless you want to keep rotating ur tires or keep replacing them IMHO
Old May 21, 2008 | 12:18 PM
AVmagneticZ
well the front is only .1 off of spec and i cant really go anymore cause of my low offset or it will rub the fender. so the only thing i can do is correct the front a bit more. with front camber kit
Old May 21, 2008 | 01:50 PM
Q45tech's Avatar
Q45tech
The in spec range is not the ideal range which is normal or nominal point.
In spec can cause serious tire wear!
Old May 21, 2008 | 01:52 PM
AVmagneticZ
well with my rear wheel setup i have no choice. because i am lowered. what is the proper SPEC then ? since theres a range what within the range is what they set it to?
Old May 21, 2008 | 02:21 PM
redlude97's Avatar
redlude97
Are your fender's rolled? Optimal specs are usually right in the middle of the range, which you are quite far from
Old May 21, 2008 | 02:22 PM
AVmagneticZ
yes my fenders are rolled without that i would rubb on most bumps
REDZED
Jul 2, 2005 11:04 AM
silverz
Cleaning & Detailing
Jul 5, 2003 11:07 AM
mf01
Texas
Feb 3, 2003 03:58 AM
Brad4rdHay
Jan 9, 2003 01:43 PM
