E-brake light coming on...
Old May 22, 2008 | 05:18 PM
VQpoweredZ's Avatar
VQpoweredZ
Default E-brake light coming on...
Sorry if this has already been covered, I was just wondering that why in my Base 2006 350z that the E-brake light comes on when the tires start slipping. Example: I just got back from driving in the rain, my tires slipped a little bit when accelrating in 2nd, and the light came on. Any help would be helpful.
Is this something I should be worried about, or is it my cars way of saying I shouldn't be slipping like that.
Thanks alot,
Dan
Old May 22, 2008 | 05:33 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by VQpoweredZ
... or is it my cars way of saying I shouldn't be slipping like that.
Thanks alot,
Dan
Yes.
For good measure, you might want to check your brake fluid to make sure it's not low. That's been known to trigger the Brake light.
Old May 22, 2008 | 06:18 PM
VQpoweredZ's Avatar
VQpoweredZ
thanks for the relpy,
is there anything else that can cause the brake light to come on?
Old May 22, 2008 | 06:35 PM
DavesZ#3's Avatar
DavesZ#3
E-Brake switch malfunction. E-brake handle not all the way down. Worn brake pads. ABS computer problem. Other than brake pads, the others aren't very common.
Just so were on the same page - you're getting the "BRAKE" or ((!)) warning light, not the ABS or ((ABS)) warning light, correct?
Old May 22, 2008 | 09:26 PM
VQpoweredZ's Avatar
VQpoweredZ
nope it was just the "BRAKE" light, but everytime it comes on, it is always when i am pushing the car a little bit harder and when it starts to slip. Ill look into the things you have mentioned.
Old May 23, 2008 | 09:38 AM
SSZVirginia's Avatar
SSZVirginia
bet its low on fluid....as mentioned before......
Old May 23, 2008 | 05:55 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
low on fluid, 9 times out of 10 = low on pads
Obadabot
Jun 18, 2023 11:31 PM
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
