Need to replace my brembo brakes soon, should I go aftermarket?
Old May 29, 2008 | 09:42 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by JETPILOT
Well... he did have ss lines, fresh MOTUL RBF600 and as I stated the NISMO R compound pads. He also had road tires. Not even R compound. I don't know why your making assumptions on my friends brake setup. Do you have a crystal ball?
When you put on R compound tires and get on a track like Sebring your going to have issues with the OEM Brembo's.
If you want to believe that it doesn't matter what track your on and that Brembo's are adequate for any situation then go right ahead. I have no idea how you drive maybe they are perfectly adequate for you.
I am talking about the OP not your friend. Pay attention. Your friend obviously needed better pads. NISMO pads aren't all that.
Old May 29, 2008 | 10:15 AM
Axelerate's Avatar
Axelerate
He needs to get the Stop Tech titanium backing plates for the Brembo fronts. They keep alot of the heat off the calipers and pistons keeping the fluid from boiling.
350z82
Oct 1, 2015 06:25 PM
