Metallic "creeking" coming from pas. rear
Old Jun 15, 2008 | 12:48 PM
SnyperZ's Avatar
SnyperZ
Default Metallic "creeking" coming from pas. rear
Whenever I take off the car makes a strange creeking sound from the rear pas side of the car..if im in first gear it creeks on accell and decel...its not a clicking sound like axles make..but who knows..anyone have any ideas?
Old Jun 15, 2008 | 07:04 PM
nkohler's Avatar
nkohler
check to make sure your lug nuts are torqued down tight. I had this exact problem and it turned out to be that I forgot to torque down one of the wheels after I swapped them, they were only hand tight!
Other than that it could be the axle hub bolt that is on the end of your hub, needs to be torqued down to 220ft/lbs
Old Jun 15, 2008 | 07:17 PM
guitman32's Avatar
guitman32
Could be your end links. Search for "end link creaking" or similar and you'll find more information.
Old Jun 15, 2008 | 07:56 PM
SnyperZ's Avatar
SnyperZ
Thats almost what I thought it could be..even with 24k miles huh?
Old Jul 2, 2008 | 04:12 PM
SnyperZ's Avatar
SnyperZ
It was the axles. They took them out cleaned lubed and reinstalled them 180* and they dont click anymore.
Old Jul 29, 2008 | 11:59 PM
SS21CA's Avatar
SS21CA
I was going to suggest; Check out your axel nuts. My driver side rear came loose and cause $1,300+ worth of damage. Brembo's got trashed, along w/ pads, rotors, hub bearing, etc....
I think I might make a nice thread about my experience later. Give some older Z owners a heads up that they might have to retorque their axel nuts.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
