wilwood line sizing
I have a Wilwood brake kit on my car as below:
http://fastbrakes.com/shop/product_i...oducts_id=1108
It uses the Wilwood Superlite 4 piston caliper. I had one of the lines develop a hole the other day and pretty much have lost all braking. I’m trying to figure out what kind of line I need to get to replace the broken one however can’t figure out what size the fitting is on the caliper itself that connects to the brake line. It’s a fitting which just screws onto the bolt on the caliper not a banjo bolt type setup. It looks like this one:
anyone know what size this fitting is? also what size do i need for the other end that connects to the hardline off the car
thanks in advance
thanks in advance
thanks in advance
thanks in advance
The caliper fitting is a -3 male to 1/8th-27 NPT male. I can get these for you no problem.
Fastbrakes doesn't give you Wilwood lines BTW hence the quality issue you're dealing with. The hardline size is a 10mm but I won't know the pitch until I get back into the office on Monday.
PM me if you're interested in new lines I can get it taken care of for you.
Alex
Alex
Alex
