Lower in the rear.....?
Old Jul 21, 2008 | 06:18 PM
12SecRD's Avatar
12SecRD
Default Lower in the rear.....? ATTENTION EIBACH SPORTLINE USERS
I am running Eibach sportline springs on my Z and the rear ended up a slight bit lower then the front. And I did not cut the rear spring perches.
Anyone else come across this with the sportlines?
Here are some pics. Hard to tell in the pics but in person I can notice the difference.
PS also added 25mm wheel spacers.
Going for another alignment soon as the first shop I went to were not experienced enough to get it set up properly.
Last edited by 12SecRD; Jul 22, 2008 at 07:12 AM. Reason: Trying to get the attention of Eibach Sportline users
marques1's Avatar
marques1
looks fine to me!!
Old Jul 21, 2008 | 07:12 PM
350z-Jason's Avatar
350z-Jason
looks perfect. anything u notice in person is probably just the road....
did you cut or roll your fenders? and did u get new shocks and camber arms?
i want these same springs.
Old Jul 21, 2008 | 07:17 PM
black06z's Avatar
black06z
Looks fine or at least consistent with a lot of other sportline pics on the Z.
Old Jul 22, 2008 | 09:53 AM
moforeynolds's Avatar
moforeynolds
Got your PM man!
...and, I think you are nuts The car looks fantastic. With my Sportlines I did not notice my rear lower than the front--HOWEVER, understand that the wheel well is larger on the front to allow for the wheels to turn, so it gives the illusion of the rear being lower than the front because there is a bit more gap.
Another thing too is that the rear of the Z at stock height is very slightly taller than the front; these springs even everything out (which is also accomplished with the spring perch mod when you use other springs).
350z-Jason, I don't know what the OP is running besides the Sportlines, but I am using Tokicos with my Sportlines and SPC front & rear camber arms/toe. I also have my rear fenders rolled; I didn't need to at first, but after settling, alignment and the 25mm spacers, they needed rolling.
Old Jul 22, 2008 | 10:00 AM
moforeynolds
For reference, this is my Z with same wheels, same springs and 25r/15f spacers (very similiar setup to yours):
Your stance looks identical to mine, don't you think?
On another note, what camber are you running in the rear? I'm at -1.8, but I may straighten it out a tad and camber the fronts out a bit more; it looks a bit odd to me if they aren't cambered the same amount. I don't think anyone else notices, but I do.
Old Jul 22, 2008 | 12:25 PM
quakerroatmeal's Avatar
quakerroatmeal
Did you guys have to upgrade the front arms?
Old Jul 22, 2008 | 05:28 PM
moforeynolds
yes, I did.
Old Jul 22, 2008 | 05:54 PM
kyleeboy770's Avatar
kyleeboy770
Default upgrade arms
hey curious what do you guys mean by upgrade arms sorry if this sounds stupid but would appreciate an explination
Old Jul 22, 2008 | 08:46 PM
350z-Jason's Avatar
350z-Jason
camber arms. the rear ones look like arms, and the front ones look kind of like wishbones.
Old Jul 22, 2008 | 10:24 PM
moforeynolds
In order to get the suspension in proper alignment, you will need to get new camber arms since Nissan didn't feel it necessary to make any sort of camber adjustment available as OE. You don't HAVE to, but by not doing so your lowered Z will not be in proper alignment, which will have you burning through your tires.
Old Jul 22, 2008 | 10:50 PM
OldDirty Z33's Avatar
OldDirty Z33
look goo kinda like the GF210
Old Jul 23, 2008 | 06:46 AM
Peteski's Avatar
Peteski
Looks great to me!
Old Jul 25, 2008 | 08:31 AM
12SecRD's Avatar
12SecRD
Thanks moforeynolds for the pic comparison and to others for the replies. Judging by your pictures it looks identical.
Also I am only using rear camber arms and toe bolts.
Front camber 1.98 and toe at .02
Rear camber 2.06 and toe at .04
I have no need for front camber and toe adjustment as the toe is in oem specs and camber is not off enough to worry about. Plus even if I had adjustable front camber I would have set at or near 2 deg to for the better handling and to match the rear.
What is others alignment specs with Eibach sportline springs?
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
