Hotchkis Coils Springs
Old Jul 23, 2008 | 12:15 PM
jason7467's Avatar
jason7467
Default Hotchkis Coils Springs
Any comments positive or negative about hotchkis coil springs before I purchase them. I have 20" Matrix rims right now and dont want to have to deal with camber alignment and rolling fenders. I was told with these springs I wont have to roll fenders or get a camber kit. Anyone else have any insight on these?
Old Jul 23, 2008 | 12:51 PM
engiNERD350Z's Avatar
engiNERD350Z
Rolling fenders has nothing to do with your wheel diameter but more due to your offset and tire width/wheel width. If your rolling diameter is the same as stock, I would not worry.
I got camber back to stock in the rear. Camber in front is not adjustable on our cars so it was -1.3 deg. Stock is -.5 deg. The shop told me that's not a huge deal.
Old Jul 24, 2008 | 07:33 PM
whitecel's Avatar
whitecel
so far i like them. Seems like road noise has increased with my stock tires. When I run my 19s, they are quiet and comfortable
Going in for alignment tomorrow
Old Jul 25, 2008 | 09:50 AM
runnun's Avatar
runnun
when you lower any car you will get pos camber (slanter outwards)
Old Jul 25, 2008 | 02:01 PM
Z04's Avatar
Z04
should have thought about lowering before buying those 20" wheels
Old Jul 25, 2008 | 02:15 PM
350Zenophile's Avatar
350Zenophile
I've been running them for awhile and not a huge fan. Going to drop the coin here shortly and spring for a coilover kit.
Old Jul 25, 2008 | 02:49 PM
Z1NONLY's Avatar
Z1NONLY
I think you mean "negative" camber. ( at least with the Z you do) When looking at the front (or back) of the car the tires look like..... / \ (although not that bad, unless you go real low.
Old Jul 26, 2008 | 12:12 AM
whitecel's Avatar
whitecel
my camber and toe wasn't that bad. I just got alignment today and they were able to get it back within specs without any camber kits or toe bolts
Old Jul 28, 2008 | 11:43 AM
jason7467's Avatar
jason7467
What dont you like about them? Are you saying you dont like springs in genral vs coilovers (which I understand)?
Old Jul 29, 2008 | 11:24 AM
350Zenophile
I don't think they pair very well with the OEM shocks but I may be in the minority on that b/c many on this site led me to believe otherwise when I was shopping. They may also have been using shocks valved to work with the softer 03-04 springs. I also frequently read that they ride like stock, but they are definitely rougher...maybe b/c of the roads in my area and maybe b/c I also added the sways at the same time. On a side note, the sways set to med. f/r destroyed my endlinks within 1500 miles (again maybe the roads in my area). Sure you can buy beefy aftermarket units for $316 from Z1 but may have kept them stock had I done more research first.
The rear spring is also softer than stock (04.5+) which basically makes the car porpoise over freeway expansion joints like an 03-04. The combination of stiffer-than-stock front and softer-than-stock rear seems skittish and mismatched at highway speeds. I think they are a good autocross setup for that reason since you never really get going too fast.
In restrospect I actually really liked the stock ride/handling...just wanted it a tad firmer with less body roll and a lower stance for aesthetic reasons. On that point...they don't quite drop enough for my liking. I was drawn to the fact that the rear drops more than the front, but even then, once installed they kinda leave you wanting more.
The Bilstein coilovers are expensive but I think exactly what I'm looking for in that they are height adjustable with progressive rates and dampers designed to work with soft springs.
derekinthez
South East
Sep 28, 2015 06:35 PM
