Hotchkis sways
Old Aug 13, 2008 | 07:28 PM
SirSpeedyZ's Avatar
SirSpeedyZ
Default Hotchkis sways
So finally after two months my sway bars are here!
Question to the vets, what setting should I put them on?
Will the setting significantly affect the ride/handling?
Thanks in advance.
Old Aug 14, 2008 | 07:09 AM
SirSpeedyZ's Avatar
SirSpeedyZ
noone?
Old Aug 14, 2008 | 08:53 AM
terrasmak's Avatar
hole 2 front and hole 1 rear for starts , the adjust as needed, if needed.
Old Aug 14, 2008 | 09:20 AM
SirSpeedyZ's Avatar
SirSpeedyZ
i don't think it'll be real easy to adjust so I would prefer a recommendation for the setting not an obvious answer.
Old Aug 14, 2008 | 09:27 AM
terrasmak's Avatar
Everyones driving style , driving skills , tires , tire stagger is different. Just set them how i said and go from there, you may be just fine, you may want to tune it up slightly. Both bars are easily adjusted without jacking the car. Each bar takes less that 5 minutes to change settings.
Old Aug 14, 2008 | 10:16 AM
SirSpeedyZ's Avatar
SirSpeedyZ
can you install them without jacking the car up?
Old Aug 14, 2008 | 10:46 AM
jason7467's Avatar
jason7467
Well like the guy earlier stated its all about your setup your driving skills and what your using it to do. I personally drive mine to work sometimes and like to drive it hard. I started with the stiffest settings on both and found my car skipping around corners. Long story short I went through them all and I fount the middle in the front to be the best and the 3 position in the rear. If 1 is the stiffest I found 3 to be the best. If you can install them without jacking up the car then you need to put on some weight or join the circus! Good luck
Old Aug 14, 2008 | 10:57 AM
SirSpeedyZ's Avatar
SirSpeedyZ
thanks for the info, that's what i was looking for
Old Aug 14, 2008 | 11:45 AM
terrasmak's Avatar
I think i had the setting swapped , full soft front and 1 up from full soft rear , basically what he said above, but he only have the 3 hole front bars.
Old Aug 14, 2008 | 05:41 PM
bbs350z's Avatar
bbs350z
i have the 3 holes as well. the newer versions have 4 i believe in the rear. mine (3 hole) is set in the middle, as i like to drive somewhat spirited from time to time on the street. when its track time, i swith it to the hardest setting, and it is very easy to adjust, just remember to torque it down. if you drive with the stiffest setting on the street, you will get tire skip, and its a pain in the ***, and potentially dangerous. if you just cruise, set it at the softest, its like oem.
Old Aug 14, 2008 | 09:48 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
i have middle hole in the front
and 3rd hole in the rear
Old Aug 15, 2008 | 04:48 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if you follow Hotchkis's supplied directions, they give you their recommended starting point
why did it take someone 2 months to send swaybars?
Old Aug 15, 2008 | 07:28 AM
SirSpeedyZ's Avatar
SirSpeedyZ
they were backordered from hotchkis for a bit, soon after they got them in intense sent them out
thanks for the info guys, can't wait to try them out
hulkout
Apr 28, 2017 09:00 PM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
