Question about R1 Concepts Brakes
Old Aug 29, 2008 | 10:51 AM
halcyon901's Avatar
halcyon901
Default Question about R1 Concepts Brakes
Hey everyone. I used the search function, and read up on the long R1 brakes thread. Seems like most people like the cross-drilled/slotted rotors. Now, i need to get new rotors and pads, and i'll be ordering this combination from R1 Concepts.
My question is, do i have to get new brake lines as well? If so, am i correct in assuming that i also have to put in new brake fluid? Thanks in advance
Old Aug 29, 2008 | 11:27 AM
sk26dett's Avatar
sk26dett
How many miles on your car? i recently changed out my brakes to r1 concepts drilled rotors, new pads, and ate blue brake fluid. I had around 60K on my stock brakes and i felt a huge difference after, i didn't change my lines. You don't have to change them, but you might feel a difference in the pedal feel and on the track.
Old Aug 29, 2008 | 11:29 AM
Brick-Z's Avatar
Brick-Z
New brake lines are not needed when installing new rotors.
Old Aug 30, 2008 | 09:16 AM
halcyon901's Avatar
halcyon901
my car has 41000 miles right now. i've been told that since the standard brakes are a bit small, i need the new stainless brake lines due to heat.
Old Aug 30, 2008 | 05:23 PM
JasonZ-YA's Avatar
JasonZ-YA
I have the R1 concept cross-drilled/slotted rotors and love them. i have them matted up with hawk pads and instantly noticed a good bite....
i think if you just swap the pads/rotors and add new fluid you should be good to go....
if u autoX and track the car and have the extra cash to drop on steel braided lines then that part is up to you....
-j
Old Aug 30, 2008 | 05:30 PM
citymunky's Avatar
citymunky
There no need for SS line, but if you I would upgrade anyway.
Old Sep 2, 2008 | 07:33 AM
halcyon901's Avatar
halcyon901
everyone, thanks for the helpful info.
Workshop12
Mar 23, 2020 01:45 PM
Vigman
Nov 17, 2015 04:34 AM
Ace2347
Sep 22, 2015 03:12 AM
