BC Racing BR-Type Coilovers Height Comparison
Old Mar 3, 2009 | 08:16 PM
  #41
steven37's Avatar
steven37
Originally Posted by johzp
^^ exactly what i was going to do, but ordered the rear spring/perch because it wouldve only made like a finger difference.
Any pics of the car?
So you got the shorter springs from bc? I don't have any pics of my car yet.
Old Mar 25, 2009 | 03:10 PM
  #42
johzp's Avatar
johzp
got it, any pics now =)
i will post mine soon
Old Mar 26, 2009 | 03:21 PM
  #43
ADMAN's Avatar
ADMAN
So, in other words, you got the BC setup and aren't happy - and had to buy something more in the end???
Old Mar 28, 2009 | 09:42 PM
  #44
johzp's Avatar
johzp
My shocks seem to bottom out and only have around 4 inches of travel. Anyone else have a problem with this?
Old Apr 3, 2009 | 07:22 PM
  #45
jaminkid's Avatar
jaminkid
Size:  143.0 KB<p>Name:  DSCN1363.jpg
Size:  121.7 KB<p>Name:  DSCN1365.jpg
Size:  138.3 KB pure sex
Old Apr 3, 2009 | 10:48 PM
  #46
terrasmak's Avatar
The shorter stroke of coilover dampers will cause less travel than stock, and the bottem out parts, the shock height out of adjustment and or the damper is to soft.
Old Apr 7, 2009 | 09:54 AM
  #47
rotchcrocket04's Avatar
rotchcrocket04
jaminkid: how much more do you have on the rears to lower? Not that I think you need anymore (IMO that's plenty low enough) but I'm just curious b/c alot of people are saying they're maxing out the rears and are only achieving +/- 1.5" in the rear. Just curious b/c I'm buying these today or tomorrow.
Also, what did alot of you guys do about camber? Front and rears? I'm probably going to buy the SPC front and rears b/c I really want to get it back into factory specs. Although, I've seen alot of guy running only rear kits?!
Old Apr 7, 2009 | 10:56 AM
  #48
jaminkid's Avatar
jaminkid
Umm. I think? I'm maxed out on the spings. But I'm not sure. I'm working on brakes so I can snap a few pics later. I'm running 18x10 with (half inch??) spacer and wheels fit pretty snugged without rubbing...(not saying I have fat fingers but I cant fit a finger between the tire and fender) 18x11 will be on next week. Might have to raise a lil or roll the fenders. Fronts have a lot more to go lower but if I do, it'll be pretty much sitting on the tire. I will take a couple pics and show you how mine is set up in the rear. I have the SPC camber kit with toe bolt. And that pretty much bought me back to specs. If you don't have any aggressiv wheels you should be fin. e
Old Apr 7, 2009 | 11:10 AM
  #49
rotchcrocket04
Cool man, thanks for the info
I'm running 20mm spacers in the front and 25mm in the rear on factory (06+) wheels. I'm pretty sure with the car dropped similar to your's I should be good.
Do you have a front camber kit (A-Arm)? Or did you get it back to factory specs without one?
Thanks man!
Old Apr 7, 2009 | 11:12 AM
  #50
MrToeknee's Avatar
MrToeknee
Sorry to keep yall updated.
I still have the regular springs in the rear.
And after getting the vortech, I wanted to drive faster so I raised the car up .5 inches
And this was my boy Soleil's car dropped on the shorter rear springs. Not even dumpt to the fullest yet.
Hope this helps.
I have the SPC rears and toe bolt but havent installed it yet.
The white one has the SPC rear camber kit installed and it got it back into the specs he wanted.
Old Apr 7, 2009 | 11:14 AM
  #51
rotchcrocket04
Helps alot both cars look excellent! Thanks for the pics bro!
Old Apr 7, 2009 | 11:52 AM
  #52
jaminkid's Avatar
jaminkid
Nothing done to the front. Plans in future. Plan to boost now
Thanks man!
Old Apr 7, 2009 | 04:11 PM
  #53
jaminkid's Avatar
jaminkid
Yeah...I'm pretty sure the rears are at the max lowering point. <p>Name:  DSCN1398.jpg
Size:  55.7 KB<p>Name:  DSCN1399.jpg
Size:  66.9 KB<p>Name:  DSCN1400.jpg
Size:  49.3 KB<p>Name:  DSCN1401.jpg
<p>
And this is what happened to me (AAM Y pipe) because I was too low pulling in my garage and out my driveway. Dont need anymore tho. Going FI and wont need a Y-Pipe.<P>Name:  DSCN1403.jpg
Size:  73.8 KB<p>Name:  DSCN1402.jpg
Size:  72.0 KB<P>Anyone wantz they can can haz for cheap.
Old Apr 15, 2009 | 05:46 AM
  #54
rotchcrocket04
I'm up in the air about these again
I've been debating between these and Stance GR+ OEM. The thing that I really don't understand is how one person has a different max drop for the rears (without buying the shorter springs).
I don't think I want to go too low, but I've been told by multiple Vendors that these will drop the rear on the ground if need be. I know BC did some sort of revision in early 2008 but I don't know if it affects max rear drop?!
For the record, I'm running factory 06+ wheels (most likely won't be changing them). I'm estimating that I'll want a little more of a drop than the GF210's. Maybe almost no gap in the front and approximately slightly less than 1 finger in the rear.
The price difference between Stance and the BC's (both with rear extenders) is $132. Thoughts? (whether you have BC's or not)
Old Apr 15, 2009 | 07:37 AM
  #55
folgrz's Avatar
folgrz
Originally Posted by jaminkid
Yeah...I'm pretty sure the rears are at the max lowering point. <p><p><p><p>
<p>
And this is what happened to me (AAM Y pipe) because I was too low pulling in my garage and out my driveway. Dont need anymore tho. Going FI and wont need a Y-Pipe.<P><p><P>Anyone wantz they can can haz for cheap.
LOL the same thing happened to me my y-pipe has been sitting in my garage for the longest time now
Old Apr 15, 2009 | 08:04 AM
  #56
MrToeknee's Avatar
MrToeknee
I guess it really depends on what you wanna do with your car.
Stance - These will def slam your car if you are going for that image. I've heard from my friends that these coilovers tend to have a knocking sound from the rear. And I've heard it from my boy's Z. He called stance and talked to them and they sent him something to fix it. Sound is no more.
-Spring Rate - 12kg(F)/5kg(R)
-15-way Adjustable Rebound
-Dual Ride Height Adjustment
-Adjustable 1-Piece Pillowball Upper Camber Plates
-Coil Wound Linear Springs for minimal sagging
-Oversized Shock Body with Annodized Aluminum Perches
BC Racing - I haven't had a problem with these coilovers yet. I am lowered to my desired height since I have a bodykit and I wanna make it over speedbumps. I don't autocross so I couldnt give you a track comparison
-10/8k spring rates
-46mm internals (53mm shocks!!!)
-1 year warranty
-30 way adjustable
Old Apr 22, 2009 | 05:16 AM
  #57
rotchcrocket04
I ended up ordering the BCs. I initially started off wanting springs, then moved to coilovers when I saw what the price of new shocks would run me down the line. Then I moved from BC's to Stance. Then I considered spending another $150+ for the next level of Stance.
Then I got pissed off at myself b/c I just kept adding more and more onto my total price... and for my needs and wants, it was overkill. I'm not looking to set the car on the ground nor will I be tracking this car often. If I do, it will see a track once or twice a year. So, I went back to BC's seeing as they have some great reviews, a good following (especially with the Subaru/Evo guys) and are slightly cheaper.
They're on the way to my house now. Probably won't have time to install until next week. I'll surely add my initial impression in this thread and the other BC review thread along with some pics
Thanks to everyone that posted up some pics (feel free to post more!) and to those who gave me their honest opinions.
Old Apr 22, 2009 | 06:00 AM
  #58
jaminkid's Avatar
jaminkid
You made a good choice bro! Enjoy when they get there! What size wheels will you actually be running? Those pics before were 18x9F and 18x10R now I'm on 18x9F and 18x11R same drop.
Old Apr 22, 2009 | 06:20 AM
  #59
rotchcrocket04
I'm on the factory 06+ wheels. I'm also running 20mm spacers front and 25mm rears. The way it sits now is verrrry flush... would have liked to go 30mm rears but then I would definitely have to roll my fenders (after lowering) and I was trying to avoid it.
Old Apr 22, 2009 | 09:16 AM
  #60
MrToeknee's Avatar
MrToeknee
You'll be happy with the coilovers.
Bump with a new picture
