Help bolt snapped!
Old Sep 15, 2008 | 01:24 PM
msmuriellz's Avatar
msmuriellz
Unhappy Help bolt snapped!
A friend of mine was helping me put on my coilovers..
One of the three bolts on top of the coilover snapped because my friend over tightened it.
Should I be worried? Should i try and bang out the bolt and press in a new nissan factory bolt,? or can i just continue installation with it having only two bolts? 350z is going to be used for track and time attack. Oh yeah these are racing logic coil overs = p And i don't think they'll cover this under their "warranty" Help would be greatly appreciated
Old Sep 15, 2008 | 03:27 PM
fart_canon's Avatar
fart_canon
I know you need an answer soon so you can continue your installation but If you dont get what you're looking for anytime soon, call your local performance shop and ask for their opinion.
Old Sep 15, 2008 | 03:49 PM
blackfairlady's Avatar
blackfairlady
1) Drill out the broken bolt with a bit smaller than the diameter of it
2) Once all the pieces of the old bolt are out, use a slightly larger bit than the diameter of your hole in order to drill the walls of the opening relatively smooth
3) Use a tap (+ tapping oil) to cut new threads, and buy a new bolt to fit.
Old Sep 15, 2008 | 06:13 PM
msmuriellz's Avatar
msmuriellz
thanks, i just wanted to get a second opinion i was going to try to bang it out (hee hee) or drill it out ! I can't believe it happened =( was trying to keep myself busy during the day and take advantage of the sun light while the city tries to restore power to us!! but thanks for the help!
Old Sep 15, 2008 | 06:24 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
I would have maybe just used some super-glue.
Old Sep 15, 2008 | 08:10 PM
PDX_Racer's Avatar
PDX_Racer
IIRC, the bolts "press-in" to the hat. If not, the hat itself isn't horribly expensive -- it's just a pain to have to compress the springs in order to get the hat replaced.
Old Sep 15, 2008 | 09:39 PM
oz_kidd's Avatar
oz_kidd
^^ 1+
i had my caliper bolt broke in my civic. i ended up using a drilling method also. and it worked.
Old Sep 16, 2008 | 03:47 AM
4thHorse's Avatar
4thHorse
What type off coilover and how did he tighten. Were you guys using air tools?
Old Sep 16, 2008 | 01:18 PM
SchismX's Avatar
SchismX
Check to make sure that you can even buy a replacement stud. I wonder if you could just buy a bolt to fit through there and secure it with a nut that fits. If not, you may need to buy a new hat.
Old Sep 17, 2008 | 01:48 PM
msmuriellz's Avatar
msmuriellz
oh no, what to do. I'm just going to drill the bolt at, and press a new one in, I was told that you only need two... which leads me to why would they make a third if you only need two..? Haha.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
