Nismo vs RS-R springs Any experience?
I wanted to change my suspension but like other do not want to lower the Z too much. Hence I was looking at the RS-R springs that drop .6" all around vs Nismo's .8" F and 1.2" Rear. Both are supposed to be progressive springs. The RS-R have a bit higher spring rate than Nismo.
Everyone that installed Nismo are generally happy with them.
However, searching this forum I have not locate anybody that has installed the RS-R springs.
May be by now someone has install them and can provide feed back.
on
I have the RS*R springs on my 350Z and like them a lot.
They are linear rate springs and they lowered the the rear .5"maybe .6", the front is lowered about .75".
I had the car realigned and the front is at 1.1 degrees negative camber after the install (originally is was at .8 degrees)
The rear is now set at 1.5 degrees negative camber (original setting was 1.3 degrees negative camber) there was adjustment left in the rear to reduce the camber more but I also changed the swaybars to Cuscos and didn't know where i wanted it for the tire size combo/springs/bars and how they work together.
I almost say to run less rear camber maybe down to about were the fronts are to increase traction in a strait line and give up a little cornering since I run a 285/40/17rear and 245/45/17 fronts.
But I could discuss the details of your specific vehicle mods with you and what you want to do with your car on a case by case basis.
I do like them and they seem to work with the stock shocks for now and it is cheaper. It leaves an extra $1000+ dollars for shocks, and Konis or Tokicos should be out this fall for under $600 for the full set and they will be adjustable and better than the Nismo without a doubt.
Re: Nismo vs RS-R springs Any experience?
Discussion on the forum may provide help to others.
1) First concern is the ride. Since I do not plan to do much auto-xing or DT'ing I would like to better balance for "touring" and remove the "porposing". I do not mind a firmer ride but to want to keep ground clearance (have you seen some of the speed bumps!). I would not consider a change except for the "porposing" that I have with current setup and tire wear.
2) Second on the list of mods is bigger brakes. Driving here in Texas heat has exposed the limits of the OEM single caliper brakes. I'm also reading the forums for the great info on the lower cost options tread.
Hence the consideration of just changing springs (RS-R vs Eibach) and the more expensive Nismo.
Professional
on
Can someone answer whether these remove some/all of the porposing/bouncing effect of the stock springs?
Is there a way to tell how much more camber adjustment I have now so I can be sure I don't require camber rods?
spn350z, what did you end up getting?
Thanks.
Thanks.
[B] Both are supposed to be progressive springs. The RS-R have a bit higher spring rate than Nismo.
B]
B]
347/419
Guess what RSR's web site says their rates are (in spite of then using general terms like this "the Down springs were engineered with a 30 to 50 % spring rate increase and efficient lowering stance." Here's the rates right off their web site
345/417 (as metioned the RSR's are linear not progressive (yes!)
And the Nismo rates would be?
Is this from the G-attack, S-tune or R-tune.
08-06-2021 06:19 AM
Extreme Dimensions
Southern California
09-24-2015 03:35 PM
