D-Specs Help
Old Oct 2, 2008 | 10:27 PM
DJL711's Avatar
DJL711
Default D-Specs Help
Just ordered my tokiko D-Specs and goign to slap them on with the Cobb Tuning springs, however I am having some difficulty on how I woudl adjust the stiffness on the rear. I have no problems with the front since they will be accessable right under the hood. The rear tower bar however does not have a hole which seems that I can access with anything. I'm thinking that I probably have to drill a hole exactly over where the D-specs are goign to go to have easy and instant access for adjustments. Was curious to see what those of you who also use the D-specs did in order to be able to get to the rear struts.
Old Oct 2, 2008 | 10:36 PM
Mike Wazowski's Avatar
Mike Wazowski
using the search function I found these threads that could help you
https://my350z.com/forum/brakes-susp...em-online.html
https://my350z.com/forum/brakes-susp...-settings.html
https://my350z.com/forum/brakes-susp...ec-shocks.html
thmotorsports
Suspension
680
Nov 14, 2011 03:37 PM
AlvinHuyN
May 11, 2007 11:33 PM
AlvinHuyN
May 9, 2007 11:18 PM
KhanMan
May 11, 2006 10:01 PM
