My Iforged don't clear Brembos in Rear
Old Aug 12, 2003 | 06:31 AM
mannZ's Avatar
mannZ
Default My Iforged don't clear Brembos in Rear
I found out that I need 1/4 inch spacers for the rear to clear the brembos.
I believe their where one or two others that had to do this. If I remember correctly it was because of the 4 inch lip.
Old Aug 12, 2003 | 06:34 AM
mannZ's Avatar
mannZ
Should I be concerned with running spacers?
What are the potential negative side effects?
Any feedback is greatly appreciated.
Old Aug 12, 2003 | 07:21 AM
2003z's Avatar
2003z
I was the first with that problem. I thought Vince wasn't selling 4" lips with brembos anymore?
Anyway, mine just barely didn't clear, so Vince sent me some generic 3mm spacers. Later I had Wadd3456 make me some hubcentric 2mm spacers, and they clear just fine. However, mine were so close to clearing without spacers, that only one side rubbed, and that was after the wheel and brake got hot.
How far from clearing are you, and what is the offset on your wheels. Mine are a +30, and with a 3mm spacer, it was +27, and they fit fine. 1/4" might put you near the wheel well though.
Old Aug 12, 2003 | 09:52 AM
mannZ's Avatar
mannZ
Thankyou for the quick response.
These wheels where ordered in the first group like yours. I received the wheels about 6 weeks ago but couldn't mount them without a car and tires.
I tried contacting Iforged yesterday and was unsuccessful. I know Vince is busy but I think this is important and he should have returned my calls by now! The fit is very close. The don't touch the caliper until the lug nuts are tightened. I think 3mm rings would work much better than the 1/4"(6.35mm) ones like you mentioned I just didn't know what was available and the wheel shop suggested 1/4" ones. I will try and see if it is not to late to go with 3mm ones.
By the way where do you get 2mm hubcentric spacers from?
Old Aug 12, 2003 | 02:27 PM
2003z's Avatar
2003z
got the 2mm ones made by board member wadd3456. you should pm him. I'm sure he still has the specs.
I noticed zoasis has been trying to contact vince for a while also.
Old Aug 12, 2003 | 04:02 PM
iForged's Avatar
iForged
Ammanuel,
I just got into town last night, and returned your call today. A 3mm spacer will solve your problem. Your order was one of the first with the brembo on the 4" lip application
JjL
East Canada
Jun 12, 2019 03:04 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
hardkicks
Sep 20, 2015 12:28 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
