I am now running 245/40/19 in the front and 275/35/19 in the rear. the rims are 9.5f and 10.5r the Work Meister S1 with Tein S-Techs. My question is will I rub when I install my Eibach Pro Kits with those measurements? I will eventually change my fron tires to 245/35/19. But for now am I clear of rubbing? Thanks.
The only way to know for sure is to see if it rubs when you put it on. I doubt if it will rub with that tire size and offset. Usually 285s is the start of the rubbing range.
