brakes sounds
hey i got a 203 track edition brake pad called wagnor breaks. I have the brembo. When i put thes last pads in they squeak alot when i go slow from like 15mph to liek to mph. I think that i need to cut/shave the top piece of the rotor so it dosent squeak. Or what else should i do
Get used to it. Monoblock brakes like the Brembos do squeel when used at low speedsTurning the rotor at the top will not make an appreciable difference, although you are near the wear limits. Consider the sound a badge of distinction.
