Which brake pad replacement?
Old Dec 17, 2008 | 03:01 PM
mrkrizzle's Avatar
mrkrizzle
Default Which brake pad replacement?
i bought my 2004 350z enthusiast model and it came with an aftermarket Brembo big brake 4 piston kit (gran turismo i believe??) well its time for pad replacements and im just wondering if the pads are identicle to the ones that come standard in the Track model 350z's. Could somebody refer me to a part # or a site that sells replacements? I've done searches and im seeing different part numbers for the same items which confused me. I've been looking into the hawk HPS brake pads as replacement. Could someone help point me in the right direction, thanks
Old Dec 17, 2008 | 03:11 PM
WTX350Z's Avatar
WTX350Z
well considering that no one here has seen your brake calipers....or your pads....this might be difficult to answer. Post, at the least a pic of the front and rear calipers...might be best to post measurements of the pads just to make sure.
Old Dec 17, 2008 | 04:08 PM
mrkrizzle's Avatar
mrkrizzle
might not be helpful but theres a picture. Brembo offers 2 main big brake kits for the Z that can be purchased: the 6 piston and the 4 piston. I have the 4 piston and the ones that come with the Track models standard are also 4 piston. So i was wondering if they have the same replacement pad size/dimensions. And im just referring to the fronts brakes. I have non-brembo OEM's in the rears.
Old Dec 17, 2008 | 11:30 PM
mrkrizzle's Avatar
mrkrizzle
bumpp
Old Dec 18, 2008 | 11:40 AM
mrkrizzle's Avatar
mrkrizzle
ttt
Old Dec 18, 2008 | 12:45 PM
Chebosto's Avatar
Chebosto
perhaps directly from BREMBO?
here's a link
http://www.brembo.com/NR/rdonlyres/A...-40F1BCEA50DC/
10392/939_CATPADSRACING_08mod1.pdf
if you know what size rotor the Gran Turismo Kit is, a simple call to TireRack might help, they sell that kit fairly regularly-
Old Dec 19, 2008 | 03:06 PM
mrkrizzle's Avatar
mrkrizzle
i have the brembo big brake kit #1B1.8032A2 . Its 355mm(about 14inch) drilled rotor, 4 piston. I called tirerack and they were not helpful.
Old Dec 19, 2008 | 05:00 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if you can find out what part # your caliper is, I can give you the range of pads that fit
Old Dec 19, 2008 | 08:01 PM
idrive_MD's Avatar
idrive_MD
2nd Z1, thats what I was going to suggest, get the part number from the caliper (you only need it from one of them). Its stamped on the back of the caliper. then companies like Z1 or even others like potorfield, hawk etc can simply tell you what works.
Old Dec 20, 2008 | 01:21 PM
mrkrizzle's Avatar
mrkrizzle
Found them. Thanks guys for your help
350z82
Oct 1, 2015 06:25 PM
