stock 04 rear brakes diy
Old Dec 26, 2008 | 05:23 PM
quietkilla6's Avatar
quietkilla6
Default stock 04 rear brakes diy
ive found DIY for front brakes (none brembo 2004) but i cant find the rear brakes and i remeber hearing there harder than the fronts. im doing rotors and pads. Im getting ready to do them tonight.
Any help? please? Thanks guys.
Old Dec 26, 2008 | 06:21 PM
DavesZ#3's Avatar
DavesZ#3
The only thing that makes them "harder" is the e-brake. You may have to hammer on the rear rotors to break them loose from the hub. Rust buildup tends to make them stick on - use some WD-40 or PB Blaster to loosen them beforehand.
Old Dec 27, 2008 | 09:11 AM
M1r4cL3's Avatar
M1r4cL3
Another thing that makes the rear breaks slightly harder is the suspension arm that sits right in front of the lower caliper mount bolt. Needed a 3" extension cuz there's no space to fit a ratchet head. Other than that, and the aforementioned need for a rubber mallet, it's dam near the same.
Old Mar 23, 2010 | 06:48 PM
WhiteNoiz's Avatar
WhiteNoiz
What about the ebrake makes it harder? I'm in the middle of trying to get one of the rear rotors off. I took the screws out of through the little hole. Hopefully that was a good thing. I cant get the rotor off though. Ive been pounding it with a hammer and 2x4. Recommendations?
I have one of the rear rotors broken free now, but it wont come out. Hmmm....
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
