grinding noise only while in reverse??
Old Jan 5, 2009 | 09:00 PM
str8dum1's Avatar
str8dum1
Default grinding noise only while in reverse??
Hey guys,
when i put the car in reverse, back up, and hit the brakes the pedal get really stiff and there is a grinding noise. There is little brake force applied. I think its the ABS acting up.
It only does this in while in reverse and throws no lights. Doesnt matter is VDC is on or off.
I think its the rear brakes that are locking up. The sensors next to the pumpking look clean and undamaged.
Any ideas??
Thanks!
Old Jan 5, 2009 | 10:16 PM
Chebosto's Avatar
Chebosto
stiff pedal might mean brake pad is either stuck or already engaged,
also check pad thickness. also if u are certain its the rear, check ebrake's drum's pad and/or the ebrake tension
Old Jan 7, 2009 | 08:37 AM
str8dum1's Avatar
str8dum1
any idea why it would only happen when i put the car in reverse though?
I'll check out the ebrake, etc as you suggested though
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
