Pictures of your Z on Tein S tech with 19"
Old Jan 8, 2009 | 09:38 PM
gs400speed23's Avatar
gs400speed23
Default Pictures of your Z on Tein S tech with 19"
I just got these Tein S tech springs and im debating on putting them on, but ive heard that people in other threads been saying that its a waste of money because the drop isn't much! but i want to see for my self! so hope there are some good samples
Old Jan 8, 2009 | 10:20 PM
burner's Avatar
burner
Don't believe everything you hear. I am running S-Techs with 19" Volk SF-Challenge wheels and the drop made the car look 10x better. The wheel gap is only about one finger and I didn't have to roll the fenders. Here is a pic. If you want more I can post a few others.
Old Jan 11, 2009 | 03:10 PM
d1mon3k's Avatar
d1mon3k
Very clean ride!
Old Jan 11, 2009 | 05:28 PM
gs400speed23
damn thats perfect! i didn't want mine to bee tooo low and freakin scrape everywhere i go! do you scrap like crazy? and i heard they ride smoother then the stock ones. but ill need a camber kit for sure huh?
Old Jan 11, 2009 | 05:30 PM
gs400speed23
Hey BURNER do you have a camber kit on yours already?
Old Jan 11, 2009 | 07:46 PM
burner's Avatar
burner
Ride is a bit more stiff but the car handles much better. I don't have a camber kit installed on my Z. To me it doesn't seem necessary because the negative came isn't too bad. I am going to take it to a shop sometime soon and have them check if my tires are wearing evenly but from what I can tell they look ok.
As far as scraping goes, its not too bad at all, just be careful. I have a Nismo front lip and even with that, the scraping is very minimal if you are careful. Speed bumps and semi-steep driveways don't seem to be a problem.
Old Jan 11, 2009 | 07:49 PM
TheOtherRob's Avatar
TheOtherRob
Burner are you running stock shocks? Your drop seems to be more than others from Ive seen on here.
Old Jan 12, 2009 | 05:43 AM
burner's Avatar
burner
Yeah, I am running the stock shocks. No other upgrades besides the springs on the suspension. The springs I bought used and I have had them on the car for awhile (had some 20's on for a bit as well) so they are pretty well broken in. I'll post another pic so you get a better idea.
Old pic: 20's with stock springs
Old Jan 12, 2009 | 10:48 AM
SuperBlack350z's Avatar
SuperBlack350z
i believe your stock shocks are blown or something. i've seen tein stech springs in person on 19s and they def don't look as low as your pic.
Old Jan 12, 2009 | 11:19 AM
burner's Avatar
burner
I don't think they are blown. I installed the springs myself and double checked everything when I had the suspension apart but I could be wrong. How would I tell if the shocks are blown? Usually if they are blown you get a floaty, bouncy ride which I don't have. I think maybe the crappy phone pictures make it look a bit lower that it really is. I will go out and take a few more pictures and post them up in a bit.
EDIT: Come to think of it, I did do another mod awhile back before the springs...The springmount cutting mod. Only did this on the rear though, and only cut about 1/4 inch off of the rubber. This may contribute to the lower ride height in the rear, but the fronts are only the springs.
Old Jan 12, 2009 | 12:13 PM
burner's Avatar
burner
Alright....just went out and took a few more pictures. Sorry this is the best I can do I just sold my DSLR camera and don't have a point and shoot, so I had to use the phone. I am running BF-Goodrich KDW's 245/35 and 275/35 incase anyone was wondering...
Old Jan 12, 2009 | 12:52 PM
TheOtherRob
Well that explains it. The spring mount mod is what is making the difference. Without that, your rear would sit up about another half inch or so.
Old Jan 12, 2009 | 01:12 PM
sosojeffcc's Avatar
sosojeffcc
yeah looks like a hotchkis drop now
Old Jan 12, 2009 | 04:52 PM
gs400speed23
just dropped my car with the tein s tech and for sure it doesn't look as low as yours, and i guess ill do the same as you did and cut the shock mounts, but that would equal to a total of 1" and some cm.. you might need a camber kit after that but i dunno. it does look better than the stock ones thats for sure thanks BURNER
Old Jan 12, 2009 | 05:10 PM
burner's Avatar
burner
No prob. Did you buy the springs new or used? If you bought them new, your car is still dropping (albeit really, really slow) and will for about a month until they are broken in all the way. I did the springmount mod to level the car out, the S-techs gave the car more of a raked stance and I wanted it more level. Even with the springs and munt mod, I think the camber doesn't look to bad. Its been fine for awhile now. Post a pic of your ride with the springs!
Old Jan 12, 2009 | 06:02 PM
abeklipse's Avatar
abeklipse
My Z on Tein S tech with 19" that I purchased used.
Old Jan 12, 2009 | 06:08 PM
phorbo007's Avatar
phorbo007
Burner, I was gonna say that no way does your car have S-Techs as your car looks lower than others, but now it makes sense because of you cutting the spring mounts.
IMHO it's a waste of time to buy the S tech to then later go through the hassle of cutting your spring mounts. You should've bought Hotchkis springs to begin with which would've given you the same after effect and still stay close to factory alignment spec.
Old Jan 12, 2009 | 06:11 PM
MrToeknee's Avatar
MrToeknee
Here is my Z sitting on S techs w/o springmount mod.
Spacers in the front with 255's and 285's in the rear make a big difference
Comparison with the BC Racing below..
Old Jan 12, 2009 | 07:05 PM
coolblue830's Avatar
coolblue830
omg that's pure sex.
Old Jan 12, 2009 | 07:40 PM
burner's Avatar
burner
I would have done that, but I got the springs free and I did the springmount mod before the install. I am eventually going to get coilovers though so it's not a big deal. I am very happy with the way it looks now and I didn't have to spend a dime...just some time.
That red Z a few posts up (sweet by the way) looks as low if not lower than mine and he is running the S-techs as well. I do think that how the drop looks has alot to do with your offset and tire/rim width and sidewall size as well.
