Any bolt on brake caliper upgrade with stock rotors?
on
I know everything but the track edition got the standard rotors. Is there a upgrade 4 piston caliper that would bolt on? Just a little more bite. I know Rotora made it for some other factory car. They used the stock rotor and just added a 4 piston caliper to it. Looks good and very cheap considering it's just a caliper.
on
Why would you think a 4 piston fixed caliper would privide " a little more bite" than a 2 piston floating or even a single piston properly designed caliper?
on
I was actually going to make a thread about the same question, but with the 12"6 rotors off the 06-08. Since our rotors are that big, i thought maybe adding a 4piston caliper with pads and lines will be cheaper than buying a bbk. I dont know if anyone has done this or maybe just wait till the 370z comes out with their stock bbk like the g37. 14" 6pistons I think. Thanks
http://fastbrakes.com/shop/product_i...oducts_id=1108 it uses the factory brembo rotors and is the cheapest BBK money can buy.
on
thanks
terrasmak, thank you very much for the info. exactly what I was looking for in a upgrade. relatively cheap and from a company thats been around. now I just need to get the money
Dark Knight
Wheels Tires
11-11-2015 08:40 PM
