Adding Swaybars.. Dangerous?
Old Jan 21, 2009 | 06:39 PM
rtiid22's Avatar
rtiid22
Default Adding Swaybars.. Dangerous?
This might be a weird question... but whatever.
I'm concerned whether stiffer aftermarket swaybars increase my chances of hydroplaning on wet roads..?
Old Jan 21, 2009 | 07:02 PM
julian's Avatar
julian
no. but if they make your car more oversteery it'll be more so in the wet.
hydroplane is more a function of tire tread depth, tire width, vehicle speed, and water depth.
jgregory124's Avatar
jgregory124
I havent had a bid of problems yet had mine on for about 5K and the only issue was popping in the front end until I installed my power grid adjustable end links
Old Jan 21, 2009 | 09:46 PM
After-market sway bars will alter the OEM ride. Not necessarily better but different.
Old Jan 21, 2009 | 09:58 PM
terrasmak's Avatar
Actually its speed VS tire pressure.
To the OP , you have nothing to worry about , and get adjustable sways.
Old Jan 22, 2009 | 07:27 AM
julian's Avatar
julian
so that means a bald 245 tire at 55 mph at a pressure better for hydroplaning (according to your statement) will be safer than a full tread 245 tire at 55 mph at whatever psi you think is optimal?
psi will affect the grip the tire gives you (and i've read people saying raise it to decrease footprint... i don't have back to back experience with psi in the rain so i can't comment on it). but it won't stop a tire from hydroplaning.
Old Jan 22, 2009 | 07:58 AM
terrasmak's Avatar
9x the square root of your tire pressure is what you hydroplane at. Tread will affect the traction you have before you are up on plane.
Old Jan 22, 2009 | 10:41 AM
Q45tech's Avatar
Q45tech
As much as people want to change laws of tire physics, impossible to overcome most of them.
Study hydroplanning in airplanes where pressure is 200 psi to achieve ~ 130 mph landing safely.
65 mph is tough even at 51 psi depending on road water depth.
A slick [worn out] tire has twice the area of a treaded tire thus the pressure will have to be doubled to create the same intermolecular friction with the road PER SQUARE INCH.
Old Jan 22, 2009 | 02:48 PM
terps's Avatar
terps
so according the logic a bald 285 will have less likelyhood to hydroplane at 55 then a well treaded 185 @same ps? i doubt that. the greater tire width reduces pressure made with ground, allowing water to get between the tire and road surface
planes have relativly skinny tires compared to there weight.
OP- the sways will have absolutely no affect on hydroplanning, because technically the term is incorrect in what you are referring to HOWEVER a stiffer suspension setup is more prone to breaking loose in wet conditions
Old Jan 22, 2009 | 03:44 PM
terrasmak's Avatar
The reality behind this, at the same pressure they will hydroplane at the same speed. The tire with the best tread will feel better before it goes up on plane.
I don't know about it once up on plane, but i do believe that your tread can also affect how stable it will be. Regardless of how stable it is , your still hydroplaning once you hit the target speed.
Old Jan 22, 2009 | 05:06 PM
rtiid22's Avatar
rtiid22
Okay, thanks! great.. I guess I'm staying stock cuz it rains here.. whenever really, just flip a coin! The Z's my daily driver..
Old Jan 22, 2009 | 05:08 PM
rtiid22's Avatar
rtiid22
So, you're saying that the lateral G's the car produces around turns before it breaks loose won't increase with swaybars?
Old Jan 22, 2009 | 05:40 PM
Slow*Jim's Avatar
Slow*Jim
Not getting sway bars because of rain is the most retarded thing I've ever heard. I've driven my Z in the rain hundreds of times with very little hydroplaning. Unless you are trying to go 120 in 6" of standing water, you'll be fine.
Hell, I drove in about 6" of snow and ice yesterday, with Hotchkis sways set to full stiff in front, 2/3 in back. No problems whatsoever.
Old Jan 22, 2009 | 07:14 PM
terps's Avatar
terps
stiffer suspension will negativly affect grip in adverse conditions, no question. is it worth not upgrading ...no. but the question was asked does it. i got stiffer coilovers and sways and still drive in the rain too, but you need to know the limitations
Old Jan 22, 2009 | 09:32 PM
terrasmak's Avatar
I've got sways and stiff coilovers and have no problems in the rain (when it rains here)
Old Jan 22, 2009 | 10:27 PM
Mazinger Z's Avatar
Mazinger Z
Your car already has sway bars.
Old Jan 23, 2009 | 02:19 AM
Z04's Avatar
Z04
you're joking right?
Old Jan 23, 2009 | 04:29 AM
rtiid22's Avatar
rtiid22
Many of you are asking whether I'm joking or telling me that I'm an idiot but I'm just a little peranoid of wet roads...
On April 15, 2007 me and my aunt were around the corner from my house with pizza and some lady in a lexus lost control in the rain and hit us head on.. my aunt passed away and I was airlifted and stayed in a hospital for 27 days. I now have high blood pressure, daily headaches and a tube/mesh inside my aorta.
Back on topic.. thanks to all who have replied, I guess as long as I don't drive reckless on the wet there shouldn't be a problem..
Old Jan 23, 2009 | 04:44 AM
Sixth_Vang's Avatar
Sixth_Vang
Don't cheap out on your tires and drive with common sense and you should be fine. I have hotchis adjustable sways on medium setting and haven't hydroplaned yet. Whenever I drive in the rain I get paranoid as well so I drive much slower. It just drives me insane whenever a semi-truck blows past me or is in front or beside me.
Old Jan 23, 2009 | 08:20 AM
julian's Avatar
julian
if you want sway bars, you should get them. they won't affect hydroplaning.
but if you set the bars so that your car is a lot more oversteery than stock you have to be extra careful when it's wet because your rear end will be more prone to coming around.
good luck recovering from your accident. if you don't have your health what's the point of having toys right?
