Clunk noise when I stop quickly...???
Old Aug 31, 2003 | 08:53 PM
E_Z_HOES's Avatar
E_Z_HOES
Question Clunk noise when I stop quickly...???
I have a Track with Brembo's and when I stop quick I hear a slight clunk from my right front. Does anyone know what this noise is ?? it's more like a low clunk... no loud but loud enough for me to hear.
Old Sep 1, 2003 | 08:03 AM
ChinaClipper's Avatar
ChinaClipper
Thumbs down
Sounds like your upper ball joint/arm bolts are loose. Before driving any further, I would recommend jacking up the front of the car, pulling off the front right wheel, and tightening all the bolts in the front suspension, especially the upper transverse arm. Let us know what you find, as while not common as a fault, an number of 350Zs have been known to come with loose bolts in the front end.
HTH.
Old Sep 1, 2003 | 08:44 AM
westpak's Avatar
westpak
SFZCC
One word: search
Old Sep 1, 2003 | 08:59 AM
tylerdurden's Avatar
tylerdurden
The owners manual says that with VDC equiped cars you will here a clunking noise under the fender when it is activated under hard braking or curves. You might get that clunk when the VDC applies brake to the non slipping corner brake.
Old Feb 5, 2007 | 11:20 PM
nightcrawler_8's Avatar
nightcrawler_8
i am getting the same clunk sound .. whenever i brake in low speeds and whenever i turn let or right .. i changed the balljoints with new ones and everythign is tight .. but the problem is still there.. what would it be ???
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
