Installed Factory Brembo calipers, question on Brake Master Cylinder
Old Jan 25, 2009 | 01:41 PM
pchio's Avatar
pchio
Question Installed Factory Brembo calipers, question on Brake Master Cylinder
Hi everyone, I just installed the factory Brembo front and rear brake calipers, goodridge stainless steel lines w/ factory brake pads and rotors. I bleed the system 2 times and ensure no more air coming out. However, the pedal is a little bit mushier. It does bite and stop very well once the pedal hit the mid height and it will get stiff. Therefore, I am just wondering if the brake master cylinder is different on the track version vs performance version. (Mine is 2004 performance edition) , anyone have any idea?
Another problem is, after replacing the Brembo brakes, whenever I step on the brake pedal, it makes a click noise right at the very top of the stroke. Is it because some air still trapped inside the brake master cylinder? Any input will be appreciated!
Thanks,
Pat
P.S. Thanks Anthony (06SC4dr) for the super fast shipping and very well shipping packaging!! Very smooth transaction!!
Update: The mushy feeling is gone, i believe it is becoz the brake pads and rotors are not bed in yet, since they were new. So after driving and braking for a while, it becomes normal again.
The clicking noise is also gone, what I did is just adjusted the VDC switch by loosing, back off a few threads and re-tighten it.
Thanks for all the inputs, guys! I really appreciate it!
Old Jan 25, 2009 | 01:51 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
master cylinder is different from track models
no idea on the clicking, sorry
Old Jan 25, 2009 | 06:19 PM
pchio's Avatar
pchio
I did some research. Found the site http://www.nissanparts2u.com/ and browse through their online catalog.
There are 2 different master cylinder:
Master cylinder, 350z, w/o base model 04-05
Master cylinder, 350z, w/base model 03-08
Brake Booster:
Brake booster, 350z, coupe, w/o base model, w/o 18" wheels 04-05
Brake booster, 350z, coupe, w/o base model, w/18 wheels 04-05
Brake booster, 350z, coupe, w/base model 03-05
Brake booster, 350z, convertible 04-05
Seems like the difference will be between BASE model and W/O BASE MODEL
So since mine is performance model, I am assuming I have the same brake booster and brake master cylinder are the same as the track model? Am i right?
Old Jan 25, 2009 | 06:47 PM
Parker01's Avatar
Parker01
If it is mushy, you still have air in your line. Give it another good bleed.
Old Jan 25, 2009 | 07:04 PM
terrasmak's Avatar
Looking at some of the parts listing like mentioned above, they listed different, yet most had the same part numbers.
Old Jan 25, 2009 | 07:54 PM
pchio's Avatar
pchio
After trying a few hard braking today, I think the new brembo is working properly and stop really really well. That kind of reminded me when I used to have a 240sx s14, I upgraded my stock single piston brake to z32 4 pistons brake. I also had the same feeling as this time due to a smaller brake master cylinder. So I think all air is out from the system and performing normally. I guess I will check with Nissan tommorrow and ask for the part number. I will keep this updated.
Old Jan 26, 2009 | 02:29 PM
pchio's Avatar
pchio
Just called Nissan, and they told me that the only difference between brake master cylinder will be the base model and w/o base model. So any model beside base actually have a different (larger?) master cylinder.
I also found that the clicking noise is from the VDC brake switch, I adjusted it and seems like the noise is less noticeable but still there. Dunno why it happens all of a sudden, i may try to switch it from other Z and see.
-Pat
Old Jan 26, 2009 | 03:06 PM
str8dum1's Avatar
str8dum1
whats the vdc brake switch?
Old Jan 26, 2009 | 03:07 PM
Jeff92se's Avatar
Jeff92se
How does one tell the base from the non-base models?
Old Jan 26, 2009 | 03:10 PM
0jiggy0's Avatar
0jiggy0
cruise control and traction
Old Jan 26, 2009 | 04:18 PM
costilla's Avatar
costilla
Where can you purchase factory brembos for a '08 at a decent price? Pchio, where did you get yours.
Old Jan 26, 2009 | 05:55 PM
pchio's Avatar
pchio
I bought it from a forum member here. Just keep an eye on the for sale forum, good luck
Old Jan 26, 2009 | 06:00 PM
pchio's Avatar
pchio
See Absence feature: (from 350 z-tech .com)
* HID Headlights (2003-2005)
* TCS/VDC: Traction Control / Vehicle Dynamic Control
* LSD: Limited Slip Differential
* Leather Seats
* Cruise Control
* Aluminum Pedals
* Auto dimming rear view mirror with Home Link
* Bose Sound System
* Brembo Brakes
* TPS: Tire Pressure Sensors
VDC switch is for the Vehicle Dynamic Control. It has 2 switches on the brake pedal, one is regular brake switch, another one is VDC switch and it probably uses for notifying the VDC computer when the driver applies the brake.
-Pat
Old Jan 27, 2009 | 01:51 PM
str8dum1's Avatar
str8dum1
thanks for the clarification on the switch. my abs activates whenever the car is goin backwards (in reverse or just rolling in reverse). no one can figure it out.
Old Jan 31, 2009 | 09:50 AM
scubasteve's Avatar
scubasteve
I'll bet your problem lies in the technique in which you bled your brakes. These cars are not to be bled in the traditional manner. I've posted on this before a few years back....
Just do a search to get the right sequence.
Good luck.
Old Jan 31, 2009 | 09:53 AM
scubasteve's Avatar
scubasteve
dup...
Old Jan 31, 2009 | 06:01 PM
pchio's Avatar
pchio
My brakes are working perfectly now. I bled it from RR > LF > LR > RF. Outer bleed hole then the inner one. I will do a search again and see what I can found once I get home, thanks for your advise tho
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SpartanZ32
Oct 22, 2015 09:36 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Alex Tappin
Sep 9, 2015 08:18 PM
ddegrande21
Sep 6, 2015 11:15 AM
