Rear rotors will not move....seriously
OK im pulling my rear rotor off to get it turned
This is a list of my steps
Pulled wheel off - OK
Pulled caliper and bracket off - OK
Disengaged the e-brake - OK
Remove rotor - WTF
Do a search on the Forum - OK
Beat Rotor with mallet - OK
Remove rotor - WTF
Apply Bolt Breaker to rotor hub area for overnight
Remove rotor - WTF
Guys and girls im lost
Im beating the crap out the rotor with a mallet and nothing is working.....i disengaged the ebrake also.......what can i do
Do you think if i pull the hub off I can get a homemade device to separate the parts?
Remove rotor - WTF
Remove rotor - WTF
Remove rotor - WTF
take a metal headed hammer and hit around the hub on the rotors to loosen it up a bit. Then use a block of wood and stick it behind the rotor and hit the peice of wood so the rotor wont' get damaged. A mallet isn't really going to knock it off. You have to hit it pretty hard.
you can use penatrating oil first if you want but it's not necessary. It seems like it won't come off but it will.
I just had the same problem. do not pull the hub, the rotors are slip ons. its just a lip in the E-brake "drum" hanging you up. pull that little rubber cap out of the lug area and rotate so that hole is apprx the 12 o'clock position. shine a light in and youll see an adjuster star wheel thingy....!
turn it with a flat head screwdriver in the grooves (one way or the other depending on which side youre on) and you'll feel it give. then bump a few times with a mallet and it should slide right off.
if you need to back the E-brake off more than that remove the ash tray in the center console and pull the brake handle up a few clicks, you'll see your adjuster nut.... back it off a few turns just dont take the nut completely off unless you really feel like tearing apart the entire console!! Good luck, I'm gonna search my manual quick to see if there are diagrams of the adjuster.
I normally do the sledge and block of wood trick but it didn't work for my rear rotors either. So I broke out my butane torch. Heated up the rotor around the hub ring and each lug stud hole and after about 2 minutes of heat, the sledge and wood broke it loose.
Heating the rotor makes it expand slightly and easier to get off. But it leaves it hot and make sure you don't burn your brake line or anything stupid like that.
I just give them a quick smak with a sledge, just hit both side on the wear surface face. Then call it a day. You may leave a slight nick in the rotor, but who cares .
i already did the penetrating oil and i even tried itafter letting it sit overnight
and i dont have a torch in my garage......lol
and i have hit it on both sides
The mallet i used has a plastic covered hammer with Lead in the inside....strong impact but no recoil
Im assuming that adjusting the ebrake springs would be the best solution
when this is prob the only reason id use it
im cheap.....LOL!!!!
Thanks tho......if that trick doesnt work......off to the store for a torch
If you don't bar-b-que I immediately demand the retractment of your statement that you hit it like a "crazy man".
No torch, no tools, no bar-b-que, and can't get rear rotors off = no man
That dont add up
LOL!
I think the answer is "unlucky and hungry"
fixed....
j/k
70K miles AND enuogh grooves where you decide to get the rotors turned=toasted rotors
just use a gear puller and yank them off (or 2 6" clamps to a heavy bar across the lugs)
http://www.zeckhausen.com/Nissan/350Z.htm
Centric Premium Rotors
Front 296mm x 24mm 1-piece vented rotors $72 Each
Rear 292mm x 16mm 1-piece vented rotors $64 Each
spend the $$ - help the economy.....
j/k
