Big rotors with oem brembo's
Old Mar 26, 2009 | 06:55 AM
BAGHDAD11B's Avatar
BAGHDAD11B
Default Big rotors with oem brembo's
I searched but didn't see any recent posts on this specifically. Is there a KIT on the market that will allow a larger sized rotor than the stock Brembo's using the same calipers?
If this has been discussed recently a link to the thread would be appreciated.
Thanks
Old Mar 26, 2009 | 07:14 PM
snaponbrian's Avatar
snaponbrian
I've been researching this too. From what I got it requires adapters to move the calipers. They don't seem to exist. And secondly the different diameter would cause uneven wear on the pads. Hopefully someone knows a way.
This kit is something I have been looking into lately, If I can't find a good deal on aftermarket bbk.
https://my350z.com/forum/brakes/4142...at-1200-a.html
Old Mar 26, 2009 | 07:54 PM
Not sure what you are trying to attain? Friction surface will be the same. 13, 14, or 15 inch rotors.
Old Mar 26, 2009 | 08:13 PM
snaponbrian
I was looking for aesthetic reasons I upgraded my wheels size and my oem bremebos look small.
Old Mar 26, 2009 | 09:51 PM
QuicksilverZ33's Avatar
QuicksilverZ33
but braking torque will increase...
to the op...the only way to do it is to get an adapter made to relocate the caliper...or buy a bigger brake kit...
Old Mar 27, 2009 | 03:37 AM
snaponbrian
is there an adapter out there ?
Old Mar 27, 2009 | 05:26 AM
redlude97's Avatar
redlude97
why is additional braking torque necessary? Its already beyond easy to get the brakes to lock up and activate the ABS. Additonal brake torque just means less pedal modulation before lockup making braking control more difficult
Old Mar 28, 2009 | 07:58 AM
QuicksilverZ33
I never said additional braking torque is necessary. I quoted davidv...and the scenario he provided...
Old Mar 28, 2009 | 01:08 PM
Ruthless18x's Avatar
Ruthless18x
Endless sells 6 piston calipers that use stock Brembo rotors.
Old Mar 28, 2009 | 04:38 PM
Z04's Avatar
Z04
Thanks
there is for the non-brembos but not for the brembo.
Old Mar 30, 2009 | 06:34 AM
BAGHDAD11B's Avatar
BAGHDAD11B
Thanks for the info.
350z82
Oct 1, 2015 06:25 PM
