Need help with Rear Suspension install
Old Apr 20, 2009 | 09:55 AM
elrooko's Avatar
elrooko
Default Need help with Rear Suspension install
Hi all,
started installing my PSS10 coilovers and I have hit a wall. The rear shock bolt is seized onto the bushing sleeve. If I rotate the nut, it turns but only about 1/4 of a turn then snaps back because the bushin itself is turning and the sleeve is seized to it.
Need some help here - I have tried about a whole can of PB Blaster, heated the end of the nut, I'm using air tools with a 450FT LB impact gun and it won't budget. I'm plain out of ideas.
Anyone hit this before and have any good advice?
Old Apr 20, 2009 | 07:25 PM
zettahertz's Avatar
zettahertz
what? I'm confused. what are u trying to do? Removing the nut from the OEM strut or putting the OEM mount onto the rear Bilstein strut?
Old Apr 20, 2009 | 07:33 PM
SilverJDMCoupe's Avatar
SilverJDMCoupe
If you talking about the lower control arm bolt in the rear, I had a similar issue, but I fixed it with hand tools. Tighten the bolt a little, hit it with Penetrating Oil all around, let it sit for a couple of minutes, then try to back it out.
Old Apr 21, 2009 | 06:19 AM
elrooko's Avatar
elrooko
I'm trying to get the lower control arm bolt out of the stock OEM shock. Basically I can't unscrew the bolt because it is seized in the sleeve inside the rubber bushing. When I try to unscrew it, the whole rubber bushing just sort of tries to spin and I can't unscrew it.
Old Apr 21, 2009 | 06:21 AM
elrooko's Avatar
elrooko
Okay - seems like I have been dumping a gallon of PB Blaster on this thing but it won't budge. If I can't get it today I may just bring it to a garage and have them cut it out with a torch and put a new bushing in. What a PITA
Old Apr 21, 2009 | 08:49 AM
zettahertz's Avatar
zettahertz
i just tapped it out w/ a screwdriver and a rubber mallet... If i remember correctly, the middle of the bolt isn't threaded.
Old Apr 21, 2009 | 09:52 AM
elrooko's Avatar
elrooko
That would work great for the front, but for the rear, the bolt is threaded onto the other side of the shock. I can't tap it out since it is still threaded through the other side of the shock.
Old Apr 21, 2009 | 10:41 AM
zettahertz's Avatar
zettahertz
o yeah, forgot about that part in the OEM strut. definitely not normal that you can't even get it out w/ the impact gun though.
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
