G35 S-techs on 350z?
Old Apr 23, 2009 | 12:50 PM
zombiepop's Avatar
zombiepop
Default G35 S-techs on 350z?
I recently purchased some used s-tech on ebay that were advertised as 350z springs, but I found out they're actually G35 springs. The information I found:
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in lbs 386/402 (final rates only, softer initial front progressive rate unknown)
Stiffer then oem by F+23% R+16% (see note at very top)
Transfers +7% roll stiffness to front
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Stiffer or softer then oem springs by R+14% R-18% (see note at very top)
Transfers +32% roll stiffness to front
Would the springs work well enough, or should I return them?
Old Apr 23, 2009 | 01:42 PM
kyx4n's Avatar
kyx4n
also, i think the drop would be slightly less, since the Z is not as heavy as the
Old Apr 23, 2009 | 01:52 PM
steve774's Avatar
steve774
Return them. The rear spring rates is completely off and there might not be any height difference since the g35 ride height is suppose to be higher then the 350z
JjL
East Canada
Jun 12, 2019 03:04 AM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
