Finally got Brembo Brakes... Off an R35...
wow. he could have just asked me for the CAD's
The brakes naked are still around $5k w/o brackets.
I wonder what the pricing is from endless.
We do not have 100% confirmation that the knuckle design is identical.
Unfortunately not alot of R-cars around to test.
If you're serious about setting up your ride w/ the r35 rig make sure to
hunt ebay. I already flipped another front set I bought there cheapo.
BTW, Endless-R doesn't make the brackets anymore. I know of only 1 place that does and it's a shop in the UK:
http://www.greenline.jp/catalogue/bb...e+Upgrade+Kits
Their kit was front only. I would be highly suspect of a complete pad/rotor
setup priced at $3k. Going rate is def $5k for good condition. I have a PERFECT
zero mile setup avail for $6k.
The newest pricing from jland for a complete rig is only $14k or so.
Stick w/ stop-tech unless you're really feeling wallet frisky.
two front calipers on ebay right now for a solid price. These look like they may have been pushed pretty hard though.
http://www.ebay.com/itm/2009-2010-OE...item3cc0097245
That's not a bad price. I've made three custom sets of brake brackets now, and each time it was about $300 not including the time spent to design it. I also have a spare front G35/350z hub that I've used to design those brackets. So you figure $1000 for the calipers, $300 for brackets, $700 for 14" rotors (more if you want the 15" ones), and it's $2000. Probably will need pads.
wish I had some CAD's of it as well. I guess I better wait until I have time to make the brackets.
I'm sure someone handy could rebuild this and still have less in a set than you did. Point was these aren't going for $8000 or whatever you said it was anymore. Did you ever get spanked in that braking contest??
Never went down as yet. Will keep you posted.
I have brackets avail. Let's just say material costs are $7-800
For a proper design. Please try to put together a set of legit,
Good condition r35 brembos for less than $5k, f/r. Then pm
Me for the brackets.
And yes, retail is over $12k.
If you're ever in Miami you can test drive my setup at no cost.
I made some big exterior updates - added do-luck front end from Flo-ridaz33, amuse ko seibon carbon rear valance and a custom logo piece for slammered, inc.
Whatcha think?
Whatcha think?
For around $4000+shipping, you can get a complete kit which contains
2x OEM GTR Calipers
4x brake pads
2x brackets
bolts and nuts
2xbrake rotors(355mm)
Will also fit V35,V36 & M35, BNR32,33 &34 & Z34
Z34 requires modification
2x OEM GTR Calipers
4x brake pads
2x brackets
bolts and nuts
